Question about GE WBSR3140DW Top Load Washer
Does'nt cycle properly
My G.E. top load washer will go through all it's cycles. However when it gets to a point to switch cycles the transmission will make a clicking noies and the motor will strain to a stop. Note:It puts a strain on the motor before cycle change takes place. After a veiw seconds or minutes it wlii resume it's next cycle ok. Please advise on where to start . Thanks Bob
  • 744 Answers
Hi.
this is a failed timer device. By replacing the timer control module it will eliminate these issues you are having and ur problem will get solved...
thank u
rate me!!!
Posted on Jun 01, 2009
My GE whdsr316g1ww will freezes during the 'Cottons' cycle
please see the next step and use the common sense: God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub
Aug 01, 2012 | GE WBSR3140DW Top Load Washer
My Kenmore 11022642 model goes thru all the cycles ok, but when it gets to the spin cycle I have to give the drum a push to get it going, it will spin with very light loads. I checked the lid switch for...
The transmission in your washer is going bad. It is not creating enough power to get up to high speed without assistance. I would start looking for a new washer. The transmission is one of main parts for the washer and it will cost over 400 dollars to fix it.
Jul 11, 2011 | Kenmore 22642 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
GE WBSR3140DW Top Load Washer Logo
109 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
