Question about GE Washing Machines
Pressure clog Washing machine won't stop filling up. I think I have found the problem there is no water pressure coming out of the (air dome?) It's like the one in the link. Can I remove this air dome....It looks like it comes off. http://216.77.188.54/coDataImages/p/Groups/260/260088/folders/197229/149874817.jpg
  • briant749 Jun 02, 2009
    But can this air dome come off? I think its clogged up. Water does shoot up out of it but then it stops again.
  • 744 Answers
Hi..
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged..
thank u
rate me fixya
Posted on Jun 01, 2009
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
Ge profile washing machine overflow
Check that the spigot where the Air Dome connects is also clean, it may be full of gunk so the dome gets no water/air pressure...
Apr 09, 2017 | Maytag Neptune FAV6800AW Top Load Washer
Maytag MAV5000 washer, water filling does not stop, small tube in back is hooked up.
Remove the small tube from the water level switch and blow through it to clear any clog in the air dome on the side of the tub.
Remove the small tube from the air dome and blow through it into the water level switch to reset it.
Then set the machine for spin and run spin cycle for 1 minute. Then try your fill again. If it does not work this time, replace the water level switch.
May 21, 2009 | Maytag Washing Machines
Washer won't stop filling. don't think it is faulty inlet valves. i can't locate any air dome/pressure switch assembly. ge washer model # wwa 8300 balwh
It was actually filling up and flooding the room. Found that a rat had chewed through a hose and repaired the hose inside the washer and it now works fine. Thanks
Jul 12, 2008 | GE Washing Machines
Remove the pressure switch hose and blow into it. Is it hard to blow through?
In the bottom right rear of the outer tub there is an air dome where the other end of the pressure switch hose is connected. The air dome can become clogged and prevent the pressure switch from working properly.
Also inspect the hose for any cracks splits or pin holes.
To access the air dome remove the cabinet shell as follows:
I will skip console removal as is seems you already know how...
With the console lifted;
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
In the bottom right rear of the outer tub you will find the air dome.
If I can assist you further, please let me know
reg501
The FixYa Team
Jun 22, 2008 | Washing Machines
Pressure Switch or Air dome?
Does it stop filling when you hit Start/pause or do you have to shut off water supply? The air dome is the black rubber piece that is clamped to the pump housing. Usually i find that clogged not letting the pressure sw operate proper. I belive the switch has 4 wires. It has 2 contacts, one closes with a small amount of water visible in tub, hi contacts close with water much higher - even filling bottom of boot.
Dec 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
what kind of washer and model # ? Sounds like.. You have a bad pressure switch or the small hose connecting to the pressure switch may be bad or the connection on the switch or tub is linking air pressure I seen where mice had chewed holes in them
Aug 28, 2007 | Washing Machines
Washing Machines Logo
293 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
