Tv turns off
I have a philips magnavox that shuts down after a few seconds of being on. it is a pr1305 I would like your input thanks  robert
I have Philips tv semi flat, I turn on totally black and there is a light rays vertical appears in the screen, what is the problem of this?
Posted on Jan 07, 2008
    Genius:
  • 1,601 Answers
Is the timer set. or does it have an automatic shut off. I would check your settings.
Posted on Oct 23, 2007
  • Thomas Christopher
    Thomas Christopher Oct 23, 2007
    why was this not helpful?
    Thomas Christopher Nov 06, 2007
    Did this work?
    Please post an answer so we can help you further.
    If it worked please rate this post as solved.
    Thanks,
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 28, 2009 | Philips 19PR19 19" TV
No picture
CK for poor solder connection around the video ic.Resolder around ic.
Dec 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
MAGNAVOX mODEL 27ms3404/17 shuts down after after a few seconds. Mine does the same thing! My TV tube turns black after sew seconds. The green light stays on saying that the power is on. If you change...
first place to start on this chasss is with a known failure in the horizontal circuit. there is a capacitor 2455 and 2 transistors locations 7461 and 7463 that have caused a wide variety of failures. i would recommend replacing these components before proceeding as they could be the whole of the problem.
Jul 21, 2008 | Philips Magnavox 27MS343S 27" TV
32mf23id philips
Sounds like the internal power supply is going bad. Loses power to the tuner first then the whole tv.
May 09, 2008 | Philips Magnavox 27MS343S 27" TV
Shut down
Sorry, I do not know that set.
Feb 24, 2008 | Philips Magnavox 20MS3442 20" TV
Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
My TV shutting itself down
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Dec 09, 2007 | Philips Magnavox 27MS343S 27" TV
TV FIX
A line across the screen means a loss of vertical sweep. This could be as simple as an IC or as difficult as a deflection yoke. These are not do it yourself repairs.
Nov 30, 2007 | Philips Magnavox TP3285C 32" TV
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
