Question about HP PSC 1350 All-In-One Thermal Printer
When I press the scan button, the 'on' light blinks for about 15 seconds then stops and nothing happens - won't scan.
Launch the scanner software - then click scan (or import),
Posted on Jun 02, 2009
My washer won't start - :control lock" light is blinking but when I start the washer nothing happens help!
press and hold the end of cycle button for 15 seconds and that should unlock the control panel
Oct 16, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Power light blinking not working cannot re set
Was there any power flicker before it happened?
1. Reset the router by pressing the reset button of the router for 15 seconds while the power cord is plugged in and while the router is powered on.
2. Release Reset button after 15 seconds and unplug the power cord of the router then press the reset button again for 15 seconds.
3. After 15 seconds release the reset button and replug the power cord then press the reset button again for 15 seconds.
If this didn't work.
1. Plug the power cord to the router, and unplug it do this 7 times then reset for 15 seconds while it's unplugged and plug it back it and press the reset button for 15 seconds and release it. Try to check if there's any changes.
Jan 09, 2010 | Linksys Wireless-N WRT150N Router
Having problems scanning items. Somedays it will work ok then others it doesn't. When i press scan on the printer the On/Off light flashes as tho it is trying to do something and it flashes on the pc for 1...
check your power outlets connect the printer to a direct plug in the wallsocket no multi adapters while machine is powered on pull out the power cable for about 15 seconds then replug power cable and tesy
Dec 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
Aug 07, 2009 | HP Office Equipment & Supplies
Scanner not working
doesn't sound like it is installed properly, try uninstalling and reinstalling, also checking the manufacture site and see if there are updates to download for it
Apr 16, 2009 | Computers & Internet
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
HP PSC 1350 All-In-One Thermal Printer Logo
352 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
