Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Calypso dryer doa
The light inside comes on when door opened, but control panel does not respond. there is no error code, just no response. is there a lockout, a fuse or is control panel itself dead? we have not had electrical storms and it worked perfectly a couple of days ago
  • 6 more comments
  • eks484 Jun 02, 2009
    gew9868kq2
  • eks484 Jun 03, 2009
    ok where are the fuses?
  • eks484 Jun 04, 2009
    someone else suggested fuses, where are they located?
  • eks484 Jun 05, 2009
    the light inside comes on when door opened, but control panel does not respond. there is no error code, just no response. is there a lockout, a fuse or is control panel itself dead? we have not had electrical storms and it worked perfectly a couple of days ago. i know it is probably the control board but could it be the fuses? and if so where are they located?
  • Anonymous Mar 17, 2014
    why should some one have to sing up for any thing to get a simple question anwaered
  • 15,935 Answers
Without actually being there to test for 120V at the controller board....Yes the main control board has failed.
First thing to check is the outlet, however to make sure the breaker or fuse has not been tripped... however no response from the machine at all indicates a primary controller failure.
If you reply with the exact model # I can help you with locating a replacement if you are going to do the replacement yourself.
Thanks for using FixYa.
If replying - please use the "Continue with this expert" option so we are connected in the future.
Posted on Jun 02, 2009
  • blueextc3221
    blueextc3221 Jun 05, 2009
    there is no power fuse - that is the purpose of your circuit breaker. There is a thermal fuse - however it would still allow the dryer to power on & spin - just not heat.
    Unfortunately all experts on FixYa are not "experts"
    President:
  • 1,197 Answers
If the display is totally out it is likely the thermal fuse.....
, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
thank you
good luck and have a nice day
Posted on Jun 05, 2009
    Scholar:
  • 62 Answers
Your control panel must be dead. You can buy a new control panel.
Follow the steps in Page #4 & Page #5. Itshows how to get access to remove the control panel and control board:
http://adcxns1.whirlpool.com/Service...D19_PILP_A.pdf
Once you lift the control panel up and hinge it back, you can take the control board off, then remove the control panel itself from its hinges in the back, then install the new control panel and your existing control board.
Good luck,
Please rate my solution.
Jegan
Posted on Jun 04, 2009
  • 822 Answers
There is no error code. check fuses inside.
Posted on Jun 03, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Frigidaire dryer LEQ2152EOS
This is indicating an open door circuit. Since the circuit cannot complete, you cannot program any cycles and the "clean filter" light will remain on until you can do so. You will find a technical data sheet inside your dryer, either just under the top panel, or inside the lower panel, if so equipped. It will explain how to test the control board and the door lock assembly.
Sep 03, 2012 | Frigidaire Dryers
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
Jun 15, 2010 | Dryers
Whirlpool Cylypso Dryer not shutting off when
sounds like the door switch is sticking when door opens drum should stop and lite comes on, check to see if switch is sticking if not then you should probably replace it also chec bulb to see if it is not burned out.You never know one could probably effect the other
Dec 18, 2009 | Dryers
Help
Does the washer start and then the error code comes up and is it completely DOA.
If it starts and then quits, it's the door switch or
If it's completely DOA, it's the main control board.
Can you let me know the complete model # please?
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool dryer calypso touch pad stopped working
CHECK YOUR INSRUCTION MANUAL TO SEE IF THERE IS A CHILD LOCKOUT FEATURE ON THE CONTROL PANEL. USUALLY, THERE IS A TOUCH PAD TO HOLD FOR 5 SECONDS TO LOCK/UNLOCK THE CONTROLS. YOU CAN ALSO TRY UNPLUGGIN THE DRYER FOR 5 MINUTES TO SEE IF THE MICRCOMPUTER WILL RESET.
Apr 21, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Calypso Dryer Electrical Problem
Problem resolved. Although the membrane control panel passed the diagnostic test, it was defective. Probably a low voltage conductor went to ground, allowing the buttons to operate but throwing the control board into error mode.
Oct 08, 2007 | Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
317 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
