Question about Brother MFC-7820N Laser Printer
Problems with Brother MFC-7820N Laser Printer turns itself off
Problems with Brother MFC-7820N Laser Printer will not turn on, it gets to light up, the display says please wait, sounds like it's booting up then turns itself off again. Any ideas on how to reset it? I have this exact same problem with the same model, MFC-7820N fax copy scanner. power on, LCD says "please wait" for approx 10 seconds fan comes on for about 1/2 second, unit powers off on its own, cycle repeats endlessly. My problem started the exact same day as info90873 may 29 2009, that is more than a little strange. My guess is some kind of hardware failure or is in the process of failing, Since the dates are the same windows update comes to mind but these devices don't get updates do they?
SOURCE: Brother MFC-7820N Laser Printer
The 7820N prints double-sided manually using the drivers. From Windows, select File / Print. On the pop-up window, click on Preferences, select the Advanced tab, click on the A/B pages icon, and select Manual Duplex. "OK" your way out. When you print, you'll first confirm to print one side of all pages. Then follow the instructions that appear.
Posted on Jan 31, 2007
SOURCE: Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Posted on Sep 10, 2008
Touch2Heaven
  • 145 Answers
SOURCE: I have a MFC-7820N printer.
clean mirrows in the scanner unit with the special liquid or 99% pure isopropyl
Posted on Nov 19, 2008
SOURCE: Problems with Brother MFC-7820N Laser Printer turns itself off
I just had same issue, it shared an outlet with a large volume work group copier, I unplugged it, opened and closed all compartments to make sure something open was not causing issues. I plugged it into different outlet and it appears to be back online. I have read some postings that this model has been known to draw over 15 amps. Its possible its starving for power. To test take to another room, plug in outlet by itself and see if it boots up.
Posted on Jun 01, 2009
  • 643 Answers
SOURCE: Scan coming out blurred on Brother 7820N Multi-Function Laser
Hello and welcome to Fixya..
If you havent already, try cleaning both the scan tray, and the glass.
That is usually the culprit ..
Also, look at the glass, sometimes over long term use, a slight condensation can form that distorts scans..
Feel free to add a comment if none of this works for you!
Posted on Nov 17, 2009
Fax automaticaly daling #365 etc like tha number how can reset my MFC 7450 printer
Found this here...
(For MFC-7420)
When you turn off the MFC's power switch its memory will be cleared. To check
whether the MFC has faxes in its memory see Checking if the MFC has faxes in
its memory on page 11-5. If there are faxes you need to save them before following
the suggestions below (See Transferring faxes to your PC on page 11-5 or
Forwarding faxes to another fax machine on page 11-5).
Turn off the MFC's power switch and then turn it on again. If the error message
continues, leave the MFC for several minutes and try it again.
Check the settings in your application software to make sure it is set up to work
with your MFC.
(For MFC-7820N)
continues leave the MFC for several minutes and then try it again. (The MFC can
be turned off for up to 4 days without losing faxes stored in the memory.)
Looking through this manual, this is the only solution that I could find. There are options on the 7820N model in the menus that will allow you to reset the printer itself, and i quick search through the above link for "printer reset" should bring you to the menu selections for that.
Jun 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, etc....it still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
My brother MFC-7820N printer was printing very light so I took out the toner shook it from side to side now it is printing very dark with shadow images of the text
You might have gotten toner on the corona, take the toner/drum unit out there is a blue knob. slide that a couple of times and try it.
Aug 30, 2010 | Brother MFC-7820N All-In-One Laser Printer
Toner on my mfc-7820n brother printer is full, but it won't print dark. VERY light only. any ideas?
Hello, I can solve this problem and get your machine back in working order. My fee is $50 for labor and part plus shipping. Let me know if you are inst rested.
Jan 05, 2010 | Brother MFC-7820N All-In-One Laser Printer
Find a printer driver
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_index.html?reg=us&c=ca&lang=en&prod=mfc7820n_all&type2=1&os=26&flang=English&dlid=
Hope that helps.
Jun 09, 2009 | Brother MFC-7820N Laser Printer
May 29, 2009 | Brother MFC-7820N Laser Printer
Brother MFC 7820N
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Jan 25, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Laser Printer Logo
286 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
