Question about Pentax K100D Digital Camera
Camera Says "Card Locked"
My camera is reading "Card Locked" however the card is not locked, and I have tried other cards with same problem.
    Sergeant:
  • 246 Answers
It seems you need to open the camera and check the SD card slot.
this tip may help you How to fix a ‘card locked’ problem
Posted on Jun 01, 2009
There is a piece on the side of the card that slides up and down. Try sliding it back the other direction.
Posted on Jun 14, 2012
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 27, 2010 | Jazz DV-179 Digital Camera
Reads Card locked when trying to delete pix from mmemory card
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 25, 2009 | HP Photosmart M425 Digital Camera
Camera says that my card is locked.
Well, you need to open up the camera to check the SD card slot. This tip may help How to fix a ‘card locked’ problem
Aug 23, 2009 | Canon PowerShot A560 Digital Camera
The card is locked
Hi!
Check the lock switch on the SD card. If it's off then it's probably a broken switch inside the camera memory card readed. The memory card readers in cameras have a small switch that detects if the SD card LOCK switch is on. This is a hardware problem, you should give it for a repair - it's not a hard repair - I usually cut off the switch and put a wire accross so the camera allways thinks that the card is not locked.
Hope this helps!
Tom
Jul 30, 2009 | Casio EXILIM Zoom EX-Z150 Digital Camera
Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
May 20, 2009 | Canon PowerShot A470 Digital Camera
Says card is locked but it is not
If there are any pictures on the card, I would back them up onto a PC and then try formatting the card in your camera to see if that helps. You should be able to read off the card even though your camera wonlt write to it.
Apr 27, 2009 | Canon PowerShot A620 Digital Camera
Canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Dec 18, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CARD IS LOCKED ON MY CANON POWERSHOT A420
I have a Canon A650 that was displaying a "card locked!" message. First, take out the card and check small the lock tab on the side of the card itself. Then, try a different SD card in the same camera. I tried an old 256 MB card from an older camera. I still got the "card locked" message. When I put the 1 GB card I was struggling with in my old Nikon, it read fine. So at this point I knew it was my camera and not the card. What finally worked for me was very gently pressing down on the metal flap inside the card chamber that detects the lock with the tip of a straightened paperclip. Hope this helps.
Jul 13, 2008 | Cameras
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Pentax K100D Digital Camera Logo
724 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
