Question about Kenmore Elite 45986 Front Load Washer
Door locked washed a rubber rug yesterday, it's backing shed into a millions pieces in washer. Cleaned out the best possible....Began laundry this am - door lock will not disengage. Need help - can't find manuel.
  • 122 Answers
Ome washing machines have a cord fixed behind the filter flap door that will open the door if pulled. Is the machine full of water, if so disconect the waste pipe and drain the water into a bucket, this may let the door open if switched back on.
Last resort use a thin flat bladed screwdriver, a blunt ended one of possible to get round the seal by the lock, you may be able to release the door
Posted on Jun 01, 2009
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
My ge washer shuts off at 19 minutes, but filter is clean
The rug backing may have gone into the pump (the white motor thing) you might take the motor out and flush it out if it is clear and it still won't pump out the pump needs replaced.
Feb 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
LG washer, rubber burning smell
Did you get this seal problem resolved, by yourself or did you call in a repair-person? If you did it yourself, was it difficult? Same problem found 12/17/10 - Thank you
Mar 16, 2009 | LG WM1812C Front Load Washer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load washer won't drain
Possibly a blocked pump. Sounds about right if it has only happened after that item was washed.
Oct 30, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
