Question about Hayward Navigator Pool Cleaner
Hayward Navigator gets stuck at wall
My Hayward Navigator gets stuck every time it reaches the side of the pool. It works fine until it meets the wall head on, but then just sits there flapping the paddles but will not turn and head off again. If you hold the hose, with the cleaner hanging underneath it (in the water) then it rotates around fine. Pressure is fine (set to 7 for 7 sections of hose) and have tried running it at higher and lower pressure. Any ideas please?
  • 4 more comments
  • steve925 Jun 01, 2009
    Yes, the cleaner has been great - it is a few years old now and during that time I have replaced the wings and feet and regularly check the pod screws are tight with no excess play. In the past when it has had a problem, it has not moved (or moved very slowly), this is the first time I have known it to move quickly along the floor of the pool (and up the sloped sides) but then get stuck at the wall. I don’t think it has anything I would call a bumper - just the plastic molding at the front that is part of the base.
    Happy to take it apart - have done so a few times over the last couple of years. Sounds like good thing to check, it would explain why it rotates when I hold it, but does not seem to have enough power to turn at the wall. Will give it a try later tonight. thanks.
    Took it apart, but no obvious signs of blockage. However, good news as I discovered there was a problem with the "cone gear" not meshing properly with the intermediate / spindle gears - it was enough to rotate the cleaner on the hose, but only if there was no resistance. After taking it apart and putting it back together gain it is all working fine. I guess time will tell if there is some wear that causes this, but it is not obvious to me if that is the case.
    Thanks for your responses, Steve.
  • Samuel Charles Spriggs May 11, 2010
    Please let me know what you find.
    thanks...
    Charlie
    There is a gear which opens a port inside the unit to divert the water to the mechanism which causes the cleaner to rotate.
    This could be clogged (causing to little power to turn the cleaner) or otherwise malfunctioning.
    Are you up to taking the cleaner apart?
    Has the cleaner worked well up to now? Does it have a bumper/bar on the front?
I have had the same Navigator for many, many years. I have replaced it's guts, pods, feet and gears whenever things wear out. I have a vinyl pool and it works great. I had a problem with it charging into the wall and just sit there beating it's feet ..... now this was my solution, and I'm surprised that Navigator has not altered the design to deal with getting stuck against a wall. This will sound CRAZY but it works great!! Take a plastic lid for a 5 gallon bucket and cut out a round-nose for the front of your navigator. The curved shape is prefect and you can notch the plastic lid and it will snug right into the Navigator body. This gives your Navigator a round-nose and it will never get stuck against a wall again.
Posted on Aug 27, 2009
    President:
  • 1,489 Answers
Great!! That would be my "or otherwise malfunctioning" speculation. Glad you found the symptom at least -- time will tell if it's the problem.
Charlie
Posted on Jun 01, 2009
My Hayward pool sweep gets stuck when it goes over the drain at the bottom of the pool
It could be worn shoes on your pool cleaner causing the problem, but it is most likely just that you need to get a ring drain cover to cover your anti-vortex drain. It creates a smoother surface and is designed specifically to work with in ground automatic pool cleaners that are getting stuck on the drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Mar 19, 2011 | Hayward Navigator Pool Cleaner
My pool vacuum just goes in circles and my other one same make is getting stuck on the pool walls
With these automatic pool cleaners, if they are going in circles, it could be one of a few problems. First, your water flow might be functioning incorrectly. Check the water flow gauge and make sure that is coming out evenly. Adjust if necessary. Also, make sure that you do not have a worn shoe or wing on one side of the cleaner. Also, make sure the navigator throat is not obstructed on one side. The same problems could be preventing it from climbing, but for that problem, you will also want to check that the hose is not too short and that the tension in the rear flap is correct.
Jul 09, 2010 | Hayward Navigator Pool Cleaner
Sweeper does not reach end of pool
Check your returns. They may be getting a flo going in the pool that keeps the cleaner from getting to one end. Usually this is due to the current pushing the floating hose around pool. To fix this simply aim the returns down into the pool rather up on the surface. It sounds like you have enough hose. I hope this helps you good luck.
Apr 15, 2010 | Hayward Navigator Pool Cleaner
Gets stuck on walls
turn down the suction if thats not the problem under the left rear pod on the body housing youl see a little straight slot for a screw driver theres 3 settings it actually shows images like a ladder turn the screw down to the first step that should solve your problem
Jul 17, 2009 | Hayward Navigator Pool Cleaner
Hayward navigator floats in pool.
Try setting it at 10 lbs of vacuum, see if that works.
Jun 27, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
3,998 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
