Question about HP OfficeJet 6110 All-In-One InkJet Printer
Worked on two other computers now it won't work on my new one....help?
I've just got a new dell computer and I'm trying to make my hp officejet 6110 work on it. It has previously worked on a hp pc and a hp laptop but now I'm getting nowhere! I have downloaded the relevant drivers from the hp website and for a start the printer appeared on the pc and said it was functional however when I actually tried to print something there was an error.....how does this happen? I'm lost I don't know what else to try!
  • 3 more comments
  • elizabeth165 Jun 01, 2009
    No I'm using XP which is why I can't understand why it isn't working....it worked on the last 2!
    Genius!!!
    I actually tried that before but obviuosly didn't do it properly thanks!
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Right click on the My Computer icon and select Properties. Does it say 64-bit anywhere on the General tab?
  • Wayne Mineard
    Hello Elizabeth,
    Are you using Vista on the new computer? If so, there is no driver to download. Comment back please and we'll go from there.
    Wayne
  • ultimitloozr May 11, 2010
    What was the error?
    Problem Solver:
  • 12 Answers
First remove the printer driver software. then go to printer & fax via start meanu then choos the add printer & follow up the instraction by windows.nest nest. now choos printer usb port then nest nest nest
Posted on Jun 01, 2009
Hp officejet 6110 all-in-one printer -- Getting error message "Press Enter to align cartridge." We've had this error before and did as instructed and it's corrected itself. However,...
turn off the printer
remove the cartidges.
Take a damp paper towel and clean the contacts of the cartridges and also the contact inside the holder of the cartridges.
put back the cartridges.
Print a self test
Also clear the the printer memory
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110- do display/needs attention light on continuously
try this
turn on/off, unplug, plug in, should reset configs. might have to do this a coupe of times
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
It will not scan. It copies and prints but it will not scan.
I had the same problem-- reinstalling the software with no results. I hooked the printer to my old laptop which had worked with the printer in the past and was able to scan. I installed the "HP Solution Center" which came with a newer printer onto my new 'problem' computer. It recoginized the 6110. I re-set the buttons on the scanner and it has worked since.
Looks like it is a 'driver/program' problem between the printer and computer.
Hope this helps.
Jul 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning?
hi
if u have proper installed scanner u see your scanner in my computer .
so u got scsner and camera wizard in my computer.then u opoen it and then folow the procedure.
Sep 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 scanner wizard
What is the OS on both the computers ?
Jan 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer wont print HP OFFICEJET 6110 all-in-one
1-if you are in any application, word, windows etc... click on
File
Print
Is the printer there hp 6110 ( if not reinstall driver)
does it have a checmark next to it? no, then right click
go to properties
set as default
put your mouse over printer, does it say ready? no, check connection or change cable.
Good luck
Nov 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
