Question about Gateway MX6025 Notebook Computer (PCMX6025) PC Notebook
Blue screen error!
Thanks both. I did try all the boot options in all modes, including safe mode. In fact tried everything that was available as an option! But it seems none will work, and everything comes back to the blue screen error. If i use the disc when i can locate 1, willmy data still be safe? Are there options to us with the disc to ensure you do not lose data? Also if using the recoevry disc didnt work is that the end???
  • gazzanet May 11, 2010
    I can't see your first messages im guessing your getting bsod all the time ?
    Is your memory bad ? if two slots or more installed try take some out and swap and change to test
    Master:
  • 404 Answers
Yes it could be, the best way is to get a new hard drive and new installation using your recovery discs. take the old hard drive to a repair shop to recover data or buy a hard drive reader for laptops.
Posted on Jun 01, 2009
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
I have a Asus G73JH Windows 7 64 bit operating system. Frequently it crashes into the blue screen of death and subsequently when i try to restart it. I get the select proper boot option error. Upon fu
press F8 on bootup and select SAFE MODE. try to login and do normal things. if this works then this is probably just a driver or application issue. if SAFE MODE doesn't work, this is probably a hardware issue.
Start your computer in safe mode Microsoft Windows Help
Mar 27, 2014 | ASUS Computers & Internet
I ONLY GET A BLUE SCREEN ON HP LAPTOP HOW DO I FIX IT
Basically Your computer crashed. First of all try to get into safe mode by pressing the F-8 Key before your computer has a chance to windows has a chance to boot.
It should bring up the windows advanced menu options. Use the arrow keys to select safe mode and hit enter.
*Just do a system restore in safe mode and pick a date to restore back before you started getting the blue screen
If the above options dont work or you are not able to boot safe mode then you will have to reinstall windows
Thanks..
Feb 03, 2014 | Lands Phones
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Will not start up and blue screen pops up with fatal system error
try booting into safe mode
tap the F8 key during boot up and select safe mode,
attempt a scan disk, virus scan (avg works in safe mode)
then reboot, if it works, fine no problem sometimes windows has a hiccup during booting,
otherwise if you have recently installed anything (including drivers) try removing them in safe mode and booting back to normal windows.
if all else fails windows reinsallation may be required
Sep 23, 2009 | Gateway Computers & Internet
Windows failed to start
It seems that you are getting a Blue Screen Error. It is also known as BSOD (Blue Screen of Death).
Try the following steps to resolve this issue
Boot the computer in safe mode - (Restart the computer and keep hitting the F8 key till you get Advance boot options. Select Safe mode.
If you are able to boot your computer in safe mode. Log in as Administrator, It will give you an alert which says the computer is running in safe mode, Click yes on that alert. You will be taken to the system restore screen. Click on next and select a restoration date where everything was working fine. Let the computer restore and restart in normal mode.
In case you are not able to boot the computer in safe mode, Please revert with the exact stop error. You will see a stop error code somewhere at the bottom part of the blue screen.
Sep 03, 2009 | HP Pavilion dv2000t Notebook
Window vista is not booting the computer
Try starting in safe mode. If it does boot in safe mode then go to HELP, THEN SYSTEM RESTORE, pick a date before you had these problems. Good luck. You start in safe mode by pressing F8 then selecting SAFE MODE from the menu.
Jul 30, 2009 | Acer Aspire 3680 Laptop
Unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Dec 19, 2007 | MSI K8MM-V Motherboard
Blue error screen when starting up computer
Ok sounds as if you may have a possible "Driver Conflict" or the like... Have you installed any software recently? If so try booting into "Safe Mode" and Uninstalling it... To try to fix it, you have a few options... firstly you can try booting into "Safe Mode" by pressing F8, straight after turn on... when at the "Safe Mode Menu" choose "Last Known Good Configuration". here is a link to help you understand... "Safe Mode" http://support.microsoft.com/kb/315222 Please find a link below to repair ya install if trying last known good, software removal etc, don't work.. http://www.webtree.ca/windowsxp/repair_xp.htm Just take it easy step by step.. ya will be back to bits in no time :)
Aug 16, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Gateway MX6025 Notebook Computer (PCMX6025) PC Notebook Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
