Question about Whirlpool LSR6332K Top Load Washer
Broken agitator The top part of the agitator is not turning along with the base. It free spins by hand almost as if some sort of a wratchet mechanism is out.
Was able to fix the problem by finding someone else that had a simular problem on this website. It was the dogs/cams. It took all of 20 minutes to repair and about $5.00 in parts.
Posted on Jun 02, 2009
michael, try running the wash cycle under different levels eg. normal, delicate etc without a load and see if it agitates.If not, the mechanism has diengaged.
Mar 03, 2014 | Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
My sleve is stuck in the spinning deal of my washer, how do i get it out?
Remove the rinse dispenser from the top of the agitator (spinning deal). Unscrew the agitator cap located on top of the agitator which is only hand tightened. Once the plastic agitator cap is removed from the top of the agitator you should see a screw which you will need a socket or an adjustable wrench to remove the screw. The agitator can now be removed by lifting strait up to free the sleeve. My only concern is how the sleeve became lodged under the agitator unless the tub became unbalanced from a heavy load. The other possibility could be the support for the tub is broken and needs to be replaced.
Feb 15, 2011 | Admiral AW22 Top Load Washer
My washer fills with water and drains but does not agitate or spin. The belt is fine. This washer is one year old.
The top of the agitater should only turn counter clock wise by hand. If it free wheels the plastic dogs between the 2 halves of the agitator are broken. Cheap fix.
Jun 28, 2010 | GE WBSR3140DW Top Load Washer
Washing machine does not spin unless I go in and start to turn the drumb. Lots of water on the floor.
Assuming that this is a top load, direct drive, neutral drain washer you appear to have two problems. No spin and a broken/leaking gasket or pump hose.
A good place to look at parts and diagrams of a basic Whirlpool washer (commercial model but consumer models are basically the same) is:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It's possible that
1. The motor coupling between the motor and transmission is worn enough that the motor cannot turn the transmission fast enough to begin the spin cycle.
2. You may have a problem with worn/broken cams in the neutral assembly. Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, and giving it a minor hand spin, the cams and torque from the motor starting throws the cams into the right gears so that the washer will spin.
Inspecting the motor coupler only requires unplugging the, removing the cabinet, pump (two clips) and the motor (two screws and two clips). Since you will do this to check out the pump anyhow, that's a start.
Look at the coupler on the motor and transmission, If it's worn badly or broken replace it. Beyond that, if it appears to be the transmission, you'll have to remove the agitators (a 1/2" drive bolt under the cap for the top agitator and a bolt into the agitator shaft. Pulling the transmission and checking the cams requires a little basic mechanical knowledge.
Remove the clutch (one spring clip), the spin pinion, 8 bolts for the transmission cover (full of 16 Oz of 80-90 weight oil) and the clip that holds the main spin gear in place. Remove that and look at the neutral drain cams. On ours, the cam with a small spring didn't have one (it has broken off) sp the washer wouldn't go into spin mode unless we hand spun it to get it started or lifted and lowered the lid.
Replace the cams, put everything back and it should work.
The waste on the floor could be caused by a leaking pump, broken drain hose or the gasket at the base of the tub. Since you'll have mose of the washer apart anyway, these should be easy to check.
Sep 21, 2009 | Whirlpool Washing Machines
Machine shakes wildly in spin mode, after replacing coupler.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Mar 16, 2009 | Kenmore Washing Machines
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 series washer
most likely the agitator dogs are bad. if the agitator engages clockwise and free spins counter clockwise they are good, if it slips they are bad. remove the bolt in the center of the agitator, take off cap or dispenser and remove the inner cap first. pull out the agitator, put on the floor, stand on the base of the agitator and pull up on the upper part to separate, take out the dog holder and replace dogs. Most appliance repair shops should have part on hand for about 5-6 dollars. part number 80040-fsp.
Jan 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSR6332K Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
