Connecting Levv home cinema system to tv
How to connect Levv SPDVD510 to LG 42'' TV
jusus
  • 57 Answers
SOURCE: connections for home entertainment system to tv
has your problem been solved or not. If not, please explain breefly about your connection to your audio or Tv.
Posted on Feb 28, 2008
SOURCE: TV sound to Cinema system?????????????
Thi is not possible so I exchanged the TV for another one, This TV does not have AUDIO OUT function.
Posted on Mar 31, 2008
  • 151 Answers
SOURCE: how to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 26, 2008
  • 124 Answers
SOURCE: connecting ps3 to cinema system
There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
Audio connections from best to least go in this order:
1. HDMI (digital)
2. Fiber optic (digital)
3. Coax - Digital (digital) <--- The one you want to use.
4. Component (analog)
5. RCA/AV (analog)
Video connections from best to least go in this order:
1. HDMI (full HD digital)
2. Component (Blue, green, red, white, red - HD analog)
3. S-Video
4. RCA/AV (Yellow, white, red)
Good luck!!
Posted on Sep 30, 2008
SOURCE: Connecting a Samsung HT-Z310 home
Do you have an Optical Audio cable going from the A/V receiver to the TV? If not, you need to get one. Since the HT-Z310 only has HDMI output and no input there is not audio bypass. Once you connect an Optical Audio cable from the receiver to the TV, anything that goes through the TV (cable audio, PS3 or Xbox 360, DVDs, Radio) will go through the receiver, too.
Posted on Feb 05, 2009
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
How do I connect a samsung c555 home cinema system to a LG 42LD450 42 inch tv so that i can get sound out the built in freeview? also cant seem to get sound out my PS3? I have connected the video output...
Use an optical cable from ps3 to surround sound and hdmi from ps3 to tv.... But I can't get my samsung surround sound to come out of the tv with built in freeview either. Just wondering if you figured it out. Cheers
Nov 14, 2010 | Samsung Audio Players & Recorders
I hvea 42 plasma tv. I have bought a cinema
Please checked Sound System with your remote menu it should be B/G,D/K,I,M which is not proper.
Dec 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i get the sound from my Philips TV into my samsung 2.1 home cinema system?
To get sound from any TV (including Philips) to an amplifier or a home cinema system, the TV should have a LINE OUT RCA pair. Thereafter, it is a simple case of connecting said Line OUt to one of the INPUTs of the cinema system.
Often (but not all), Cinema Systems have their own TV tuner and would provide a video out that could be connected to the Video IN of the TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Samsung Televison & Video
Getting audio from LG TV to play through Samsung Home Cinema System
May 20, 2008 | Audio Players & Recorders
Mar 28, 2008 | Panasonic Audio Players & Recorders
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
114 people viewed this question
 Grubhead
Grubhead
