Question about Samsung HL-R6167W 61" HDTV
HL-R5067W Ballast issue? Or Not.....
I am having the same issue Shows a gray and sometimes some green lines the screen when i turn it on. I can see a light in the back but TV is on, however it turns off after about a 1 min. I noticed a solution posted for a problem close to this. I do hear the color wheel spinning by the clicking noise however, I unplug it after it shuts down and gives me a reading that it is in standby mode. If I repeat this process two times in a row... then the tv works perfect and it will keep working all day as the temperature is heated up in the house and outside. This only happens in the morning when the TV is starting from a cold start. Would I still assume it is weak ballast? Would it need to have an aggressive reset? Or is a temperature switch of some sort. This just started last week, and I would say that the tv has about 1200 hours total on it. PLEASE HELP! David L. Le
  • 231 Answers
SOURCE: HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Posted on Dec 14, 2007
SOURCE: no sound or picture HL-R5067w samsung
alread change the lamp and fan did not work
Posted on Feb 09, 2008
localwonder
  • 6784 Answers
SOURCE: HL-R5067W
OK, this is a weak ballast that is causing the shut down, the ballast is unable to maintain a steady current due to its damaged circuitry. When the ballast is weak, it will try to power up the lamp and give about 3 to 5 clicks. if the main Board doesn't get a clear signal for the ballast, signaling the lamp is at full power, it will shut down the entire set ti prevent a fire.
The part number is BP47-00027A
Posted on May 07, 2009
  • 230 Answers
SOURCE: ballast on samsung hlp4663w
The transformer can't damage the new lamp. Faulty transformers normaly take out the driving transistors or the fusible link in the power supply, if these are good then just replace the lamp. Espacially if you know the lamp is bad (test it by swapping with the others if unsure)
Posted on May 25, 2009
  • 4090 Answers
SOURCE: Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Posted on Aug 01, 2009
Samsung hl-r5067w, sometimes when I cut on the tv it will have white vertical lines all the way through tv and gray background, no picture but you can hear the shows and turn channels but cannot pull up...
Bad capacitors on the power supply board, they are vented swollen or puffed up on Top.
Look on Encompass Parts Distribution website for list of parts /prices
1-800-638-3328
Oct 20, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a HL-R5067W Dlp. Turned it on and have verticle black lines. Eight lines then 1 1/2" space then Eight lines repeated across complete screen.
It sounds that dlp chip got defective and need to be replaced to fix the lines issue. Local tv repairman will help you to get it replaced if you do not have experience of tv repair.
Hope this info will help you.
Thanks.
Jul 07, 2010 | Televison & Video
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
Aug 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung television - HL-R5067W flickers green =DVR player
if this doesnt happen on anything else you may have a bad cable somewhere or even worse a bad dvr. check cables first.
Jul 01, 2009 | Samsung HL-R4667W Rear Projection...
HL-R5067W
May 07, 2009 | Samsung HL-R6167W 61" HDTV
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
My tv turns off
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HL-R6167W 61" HDTV Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
