Question about Frigidaire Freezers
Not cooling properly and water dispenser and ice maker not working
I have a Frigidaire side by side model FRS26LF7DS2 that is not cooling properly. The lower level of both the refrigerator and freezer both freeze food and have ice buildup underneath the trays while the upper levels are warm. In addition, both the ice maker and the water dispenser stopped working all together. Has anyone else experienced this problem? If so, how did you resolve it? Any assistance you can offer would be greatly appreciated. Thanx a bunch! Michael
duby1990
  • 367 Answers
SOURCE: Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Posted on Nov 19, 2008
Maytag317
  • 1136 Answers
SOURCE: FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
Posted on May 24, 2009
  • 82 Answers
SOURCE: refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Posted on Jun 14, 2009
nnesmith
  • 162 Answers
SOURCE: I have a Frigidaire ffu1466gw0 Upright Freezer.
if the compressor is running, the fan beside the compressor and the fan in the freezer should both be running, dirty coils can cause a problem. frost buildup on back of freezer wall is indicative of defrost problem.
Posted on Jul 26, 2009
Refrigerator side not cooling and freezer not freezing properly. Ice maker not making ice!
call your local repairman . it possibly needs freon added and only certified people can do it .
Mar 17, 2016 | Samsung RS261MDBP Side by Side...
Ice dispenser turns on randomly. It has done this 3 times during the past hour. Can this be easily solved? If not, can the the freezer alone be turned off?
Hey Dunstin, thank you for your inquiry!
From what you have described your Frigidaire refrigerator is dispensing ice at random times. This could be a miscommunication within the control panel and I would recommend performing a reset. You can reset your refrigerator by disconnecting power from it for at least ten minutes. If you continue to experience an issue with your ice dispenser I would suggest contacting a professional technician for proper assistance with repairs. I hope this information is helpful to you. -Matt
Jan 29, 2016 | Frigidaire FFHS2622MS 26.0 cu. ft. Side by...
Why don't the water dispenser and ice maker work?
You're on the right track. Clear the line, and it will probably work.
May 18, 2015 | Frigidaire FGHF2344MF Gallery 22.6 Cu. Ft....
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
No water to ice maker. Water dispenser works fine.
The dual water valve is not working or is leaking and water freezes up in the ice maker filling tube and when it needs water won't go through.
Aug 13, 2009 | Frigidaire Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Nov 15, 2008 | Frigidaire Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Freezers Logo
85 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
