Question about HP Compaq 6720s Notebook
I want to replace the Display of my Compaq 6720S and need the removal instructions for this. Thanks.
I need LCD removal instructions for Compaq 6720S
    Master:
  • 404 Answers
They're hard. if you haven't done it before its not worth it. not only the front bezel need removing but the whole laptop ripped apart this is due to the bending in the design on the power plate.
Posted on Jun 01, 2009
Laptop comes up but screen remains black
If you have access to an external monitor, try connecting it to the laptop. If you have video, then press and hold the Fn key and tap the F7 key. This toggles the video from LCD only to external monitor only to both in three taps. If you still have no video on the LCD but you do on the monitor, shine a bright light on the LCD display. you may see the video displayed. If so, then you have either a bad back-light or a bad LCD inverter in the laptop display. I would suggest replacing both to be on the safe side. A bad LCD can damage the inverter and a bad inverter can damage the LCD.
Mar 30, 2011 | HP Compaq 6720s Notebook
Halve my Compaq 6720s' keyboard doesn't work, How can i fix this without paying too much?
keyboard doesn't work usually caused the path of the key on the keyboard is dirty by the dust and liquid.
1. remove the keyboard from the laptop (see instruction how to replace keyboard)
2. remove all the key (you should do this step carefully because the mounting of the keyboard is weak)
3. you will see the key path of your keyboard clean it using some alcohol better 90% alcohol (you can find it on drug store)
Jan 16, 2011 | HP Compaq 6720s Notebook
I have a laptop which is hp widows vista,compaq 6720s. my little boy went on it and the screen side is has crack and doesn't work. what should i do HOW MUCH DOES IT COST TO FIX IT
The replacement panels for the Compaq 6720s range between $85.00 USD and $110.00 USD depending on where you order them from. The replacement is a relatively easy procedure, but I don't recommend it for a first-time novice do-it-yourselfer.
Here are links to some places where you can order the display panel:
http://www.blisscomputers.net/hp-compaq-6720s-laptop-lcd-screen-15-4-wxga-glossy-ccfl.aspx
http://www.screencountry.com/index.php?section=products&model=HP%20COMPAQ%206720S&brand=HP-Compaq
http://www.r3electronics.com/index.php?option=com_virtuemart&Itemid=1&page=shop.product_details&flypage=flypage.tpl&product_id=1147&category_id=38
Now the good news is you can still use your laptop if you have an external monitor. You can use the appropriate "Fn" key combination to switch your display output to the external device. I believe for the Compaq 6720 is the "Fn" key & the "F4" key. Connect the external monitor then power on your machine, Press the Fn and F4 key simultaneously until you get the display showing on the external device.
One more thing, you will need to go set the laptop to not do anything when the lid is closed. You can do this via Start -> Control Panel -> Power Settings. Change the custom power settings for both "A/C" Power and "Battery Power" to "do nothing" when the lid is closed. By doing so, you can close the laptop lid without shutting off the computer. Of course you will need to add an external mouse and keyboard to continue using the computer, but by following these instructions, you can basically use the laptop, even with a damaged screen, pretty much the same way you would use a desktop. The portability is lost, but the function is retained until you can have a new display panel installed.
Hope this helps FixYa! Please take some time to leave some feedback and a testimonial if you found this information helpful.
May 08, 2010 | HP Computers & Internet
Replacment sound card for hp compaq 6720s.
Your system does not have, in a soundcard per se. It uses integrated audio that is capable of delivering the features and high-end performance of an add-in audio card.
Ergo, assuming you are lacking sound, you can mosey on to the HP site and look for what they refer to as a 'softpaq'. Use the HP search engine on their website (rather pertinent results if i may say so myself).
1. Download the SoftPaq .EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
Jan 19, 2010 | HP Compaq 6720s PC Notebook
Hp compaq 6720s
Check the display on External monitor, if the external monitor works fine, it could be an issue with the LCD and controller for the system board, better to replace the LCD.
but before that just be in a safer side.
Update graphics driver and new version of BIOS from Hp.com
Jul 06, 2009 | HP Compaq 6720s Notebook
Removal of keyboard
Here is the service manual for your printer:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01293339/c01293339.pdf
page 50 of the manual shows you exactly how to remove the keyboard from your laptop.
May 16, 2009 | HP Compaq 6720s Notebook
Screen is blinking very frequently
Hello, this is a known problem with the model of that laptop. You will also notice in safe mode your screen will not flicker but in normal mode it will flicker.
Your laptop should still be under warranty and needs the LCD replaced.
Mar 04, 2009 | HP Compaq 6720s Notebook
HP Compaq 6720s Notebook Logo
617 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
