Question about Faema FA60081
User Manual for Faema D92/A, doesn't dispense coffee, only water
I'd be so grateful if anyone could please provide me with some information about how to find an instructions and specifications manual for this machine, to try my hand at troubleshooting it. All I can read on the machine is this: Model Faema d92/a fabrication 082014 01310831520 date of manufacture 05-2000 As I bought it second hand and it had been on storage for quite a while, I can't make it to dispense coffee. Thank you very much for your help.
    President:
  • 1,618 Answers
This will take some time so bear with me.
The problem with the machine is most likely the solenoid valve(black or blue electrical box connected on the side of the group), for easier access remove the front panel there are about 5 screws holding it in place, 2 on the bottom and 3 on the top under-side. Disconnect or turn off the water supply. Then using a 14mm open end wrench remove the nut and the discharge pipe. Do Not remove the 4 small allen wrench screws on the brass piece connected to the machine. Now remove the electrical box over the silver pipe, and using a cressent remove the silver pipe from the brass rectangle square. Slowly open the water supply, if water shoots out then the head is clear, we will move on if not, use a pin and clean the middle hole. Check the silver pipe also there is a small plunger in there press it in if it moves freely then we are good, if not you can try soaking it in puro caff until it clears or just get a new solenoid coil. Remove the shower screen and screw in the group head, you can soak those also.
If you still cannot get water, then we will have to go deeper into the machine.
Posted on Jun 03, 2009
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
I just purchased a Faema d92/s1. I need a operators manual and a parts. Where can I get them?
GO ON THE INTERNET AND THE BRAND NAME OF THE MACHINE. MAY
BE ABLE TO DOWNLOAD OFF INTERNET.
Sep 19, 2011 | Faema Emblema
I purchased a Faema D92/S-1 from a restaurant that was closing. I was wondering if there is a place where I can find directions on how to operate it. Also, looking for replacement parts such as side...
try to get www.nuovaricambi.it (usa office) and ask them for service in your area, they are selling spare parts to services.... good luck and all the best
Feb 03, 2011 | Faema FA60081
I am looking for parts for model D92/A2. Where can I find them?
We carry a full line of faema parts. we are located in Portland OR
www.espressomachineexperts.com
what are you looking for?
Oct 14, 2010 | Coffee Makers & Espresso Machines
Bought a used Faema Eurostar Combi. Don't have a
If it's the same as the used one I just picked up, there is a dial position for coffee, with a little cup on it. The dial position for steam is the one that cares about the positoin of the steam/hot water button.
The coffee position will never use steam and you don't need worry about the position of the steam button if you're not frothing milk.
Jun 29, 2010 | Faema FA60081
Does the Faema D92/A-2 have a bacl flow valve on it so the steam will not back flo into the city water system
A backflow preventor is normally installed by your plumber on the inline for the machine.
Oct 30, 2009 | Faema FA60081
User Manual
Please email me tomorrow at dspringer5114@hotmail.com. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
May 31, 2008 | Faema Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
1,560 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
