Question about D-Link DI 514 Wireless Router (DI-514)
D-Link 514 model
My wireless router has always worked fine until I bought a new laptop and now the new laptop will not connect to the wireless router. It keeps asking me for a key but I have forgotten it. How do I fix this problem please?
  • 43 Answers
     UNPLUG YOUR ROUTER (BUT KEEP IT ON )
AT THE BACK OF THE ROUTER ,THERE IS A RED SMALL RESET BUTON,,USING A PIN OR BALLPEN  PRESS IT AND HOLD IT FOR ABOUT 30 SECONDS,
NOW CONNECT THE ROUTER AS IT WAS BEFORE.
Check these Steps .
1.
After logging in with your user id and password, the Home > Wizard screen appears.
Click Wireless from the menu on the left side of the screen.     2. The Home > Wireless screen appears.
Let's look at each of these fields in detail.
Wireless Radio: by default, the wireless radio is on. To turn off the radio and disable all wireless functions, select Disabled.
SSID: This is the name of the WLAN. By default, the SSID name is default. This field can be used to either connect to a pre-existing WLAN or create a new WLAN.
Channel: this field displays the current wireless channel. The default setting is channel 1. You can have the router automatically select the best channel to use by selecting the Auto Select option.
Proceed to the next step to learn about the remaining fields.     3.  Mode Setting: If your network is using only 802.11g devices, set this option to G Mode. Otherwise, set this option to Mix Mode.
SSID Broadcast: Select Enabled to broadcast the SSID from the SSID field to the entire network.
Security: From this drop-down list, select the type of security (WEP, WPA, and WPA2) you wish to enable for the network. The default setting is Disable. See the WEP & WPA Setup walk through for more details on setting up security.
Click the Apply button to apply any changes you make
Posted on Oct 23, 2007
    President:
  • 2,961 Answers
The key number will be listed in the router settings as you must have security enabled in the router, if you cannot find it then simply reset the router at the rear of the unit and start again as there will be no security key number and all the settings will be back to factory default.
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Model 514
I'd check the manual for all your answers.
You can download yours HERE.
Make sure you choose the correct revision. Your router will say which version you have.
Hope this helps!
Let me know if you have any more questions or problems.
Best of luck!
--RescueTechLA
Nov 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cant connect to my router through laptops built in wireless/ps3
restart your wireless router and try again...
check the settings on your wifi router and on your desktop....
Jan 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
Trouble creating wireless access point from D-Link DI-514 router
1. Connect a pc to the router using a cable (wireless won't work)
2. Open a browser and type in: 192.168.0.1
3. Login with username: admin password: (blank)
4. Browse around the menus until you find a setting similar to "use as access point" and select it.
5. Save settings and log out.
6. Connect a cable from a port on your main router to this router's internet/wan port.
Dec 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Which d link pcmcia card will work with a d-link 514 wireless router?
Hello pig86
Your router is uses the 802.11b wireless standard. You can use a PC card that works w/ 802.11g or 802.11b. Those that are compatible w/ the 802.11g standard are also "backward compatible". In other words, they will also work w/ the older 802.11b wireless standard.
You don't have to purchase a PC card made by the same manufacturer as your router. You can mix and match manufacturers of your networking hardware/equipment just fine. They all adhere to the same industry standards.
As for choosing a specific PC card for your laptop, we'll need to know the make (manufacturer) and model of your laptop.
We will also need to know what operating system your are running on your laptop. (We want to make sure that drivers would be available for the PC card when running w/ your operating system.)
If you'd like us to help you w/ that, just post back here w/ that information and we'll be happy to.
For documentation on your router, please, go HERE.
Please, let me know if this response was "Helpful" or "FixYa" for you or, of course, if you have more questions, etc on this topic.
If I did not answer your question satisfactorially, plz, b4 assigning a "Thanks for Trying" or lower rating to my "Solution", let me know. I may have misunderstood you or the problem you are experiencing.
In any case, I will work w/ you until your problem is resolved or diagnosed. I promise! :)
Thank you
BJ
Apr 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI 514 Wireless Router Problem
you upgrade new version firmware in your wireless router
Apr 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
378 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
