Question about Car Audio & Video
My car's sub is ''sub-par'' my expectations
I just purchased a ford explorer. I replaced the factor subwoofer (which was blown) with a new audiopipe subwoofer. The woofer is 6 1/2 and has an rms of 75 watts. When I first installed the woofer, it sounded horrable. I took it back out and found that I had blocked it's blow hole and not to mention, I only had one side of the speaker wired up. The speaker is a dual core. I unstoped the speaker and jumpered the wires to the other terminals. The bass sounds much more powerful but still has a little distortion. And now when I turm it up to high, the woofer cuts off. I don't know if this is the amp or the speaker and don't really know how to trouble shoot it. The speaker houseing is totally inclosed so I drilled a 7/8 hole in it which seemed to help but did not fix the problem
  • 655 Answers
Hello css42103,
You did not specify the impedance or the model of your Audiopipe replacement woofer but if it is the TS-V6 DVC 6.5", then the impedance of each voice coil is 4ohms. If you wired the coils in parallel, you now have a 2ohm load to the amp. At 2 ohms, the amp tries to produce more power, and even at moderate volume, can be driven into clipping causing distortion. Not good for the amp. Definitely not good for the woofer.
I'd try wiring the woofer coils in series and see if it stops cutting out.
Hope this helps.
Posted on Jun 01, 2009
I have a Kenwood KFC-XW1100DVC sub woofer and it sounds blown.it was working fine when i took it out of my jeep.I put it back in and it worked fine for 5 minutes the started crackling.
If you're sure that you didn't drop the subwoofer while handling it outside of your Jeep, make sure your connections are solid. Perhaps you did not connect your wires from your terminal to the voice coils solidly. Otherwise, use your best judgement and determine whether or not the subwoofer is up to par on its normal performance. Try to keep the volume down for a little bit, to give it some rest.
Mar 01, 2011 | Kenwood KFC-XW1100DVC Car Subwoofer
I have a 1998 Ford Explorer Eddie Bauer 4 door. Recently, my roommate (the car buff) and I replaced the subwoofer. Now my battery is being drained. Things work fine once jumped. Can turn the car off and...
If it's a powered subwoofer yes. Powered subs draw alot of power, and if you wired it direct, yes it can drain your battery down. You need to wire it to a source that is powered only when key is on.
Feb 23, 2011 | 1998 Ford Explorer
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
2004 ford explorer
http://www.crutchfield.com/S-Znj3xq3asno/
Look at this site to get an idea of what will fit and what is needed for your vehicle.
Jul 11, 2009 | Sony Xplod XS-S680CX Coaxial Car Speaker
2002 Ford Explorer Sport - Blown Subwoofer
yes you can replace it but is gonna be costly,because your gonna need a box plus the new woofer,any after market will not fit plus will require more power ,so your gonna need a bigger amp,plus wiring etc,,,,,re consider using a factory sub again or replace the sub plus the amp..check the replacements and amps at crutchfield..good luck
Jul 10, 2009 | Car Audio & Video
1999 explorer stock subwoofer
I would be very proud of that truck as the sub that came with the truck was only a 8". The only one that works is the factory model as it is a 1 1/2 - 2 ohm speaker; replacements are 4ohm. You will have to replace the amp as well if you put in an aftermarket sub. Oh and apparently the amp will have to have "speaker level" inputs as opposed to pre-amp inputs. I have a 1999 Eddie Bauer wih a blown sub and I'm trying to decide what to do as well. The speaker is $400 with tax in Canada! Good luck.
Mar 06, 2009 | 1998 Ford Explorer
Blown subwoofer
1400 is PEAK power. not to be mistaken with RMS. 1400W in SHORT bursts.
RMS on them is 500-600W.
Your amplifier gain may be improperly set. How big is the enclosure and what amplifier are you using. All of these things will play a factor in answering your question. Dont expect a $400 experience from $100 subs.
Dec 26, 2008 | Pioneer Audio Players & Recorders
Sub woofer not working
maby a fuse or blown speakers try to replace the fuse
Jun 23, 2008 | 1999 Ford Explorer
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
