Question about iLO DVDR05 DVD Recorder
No power it is making a winein noise and no power
WARNING: The Following WILL violate any warranty on your product...
Only do this if you know something about soldering and some electronics expertise.
After listening to the whining for a few seconds I realized that the sound was coming from the power supply inside.(because of where the plug was in the back of it.
I opened the case and did a visual inspection of the power supply board. It's not closed in a box or anything. The whole outfit inside is really simple and easy to work on.
I checked the fuse and I could see that it was still good.
Then I noticed that 4 of the main capacitors were swelling on the top and looked like they were about to pop. I know this because I've had this problem on several motherboards on different computers.
I also know something about capacitors.
Anyway, On mine there were 2 -> 2200 Micro Farads 10v and 2 -> 1000 uf 10v that were bad. Yours might be a different set.
I un-soldered them and replaced them with good capacitors.
I got mine off of some old motherboards and power supplies that I had lying around.
You can usually buy them at your local radio shack, electronics hobby shop, or just order them online.
My player is working like it is brand new and the best part was I only gave $2 for it at a thrift store.
I guess someone got rid of it by dumping it on a thrift store.
I hope this was not to technical 4U and I hope it helped.
Posted on Jun 14, 2009
  • rukidin Feb 16, 2011
    Did not have 2200 Micro Farads 10v used 16v instead worked like brand new.
    THANKS
  • 122 Answers
You probably killed the drive flashing it. buy a new one and do some research before you buy one. get a liteon drive which has region free hacks that can be used.
Posted on Jun 01, 2009
Acura 3.2 tl makes a noise when started in the morning in cold
that noise is 1 of your belts. there is 3 belts on it. and with the power steering noise I think it is your power steering belt needs to replaced or agjusted
Nov 11, 2012 | 2005 Acura TL
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
Make make a labor some noise at some time , compressor starts and
I have the same problem....throw this unit out and never buy Danby....shame on Danby for selling junk....
Jul 21, 2010 | Danby Portable Air Conditioner
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
2003 BMW 325i will start but making noise
It might be a faulty power steering pump. Try checking the level of the power steering fluid. It is probably best you have your power steering system checked by a mechanic.
Does the noise occur only when the vehicle is moving?
Try moving the steering wheel from side to side, while stationary (but don't do it too often, or you might damage something). If the noise is still present when the car is stationary, then it probably is the power steering system.
If the noise only occurs while the vehicle is moving, it could be a problem with the differential/final drive, or even wheel bearings.
Apr 16, 2009 | 2003 BMW 325
Noise when I turn my steering wheel.
If there is fluid in the pump and it makes noise, that may indicate that the pump is going bad. Some PS pumps just make noise. Ford pumps, for example make a lot of noise, and there is nothing wrong with them. If it's a squeal, it might mean the bearings in the pump are going bad.
Nov 07, 2008 | 2003 Honda Accord
iLO DVDR05 DVD Recorder Logo
241 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
