Question about HP LaserJet 3050 All-In-One Printer
No print catridge error showing on display
"No print catridge" error displayed on hp lj3050 printer.. any solution....
  • 66 Answers
Plz remove the catridge and reinstall the catridge properly then uninstall the printer driver and restart the system then after restarting the system then reinstall the printer driver and restart the system again then after restarting the system check
Posted on Jun 01, 2009
No catridge show on display hp laserjet 1005mfp
I suggest You Go to Official Hp Printer Page For You HP Printer Problem On Below HP forum URL Link: No print cartridge Message Displays on the Product In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Printer Support
Feb 26, 2014 | HP LaserJet M1005 Printer
Empty cartridge warning
Most problem experienced with hp photosmart c6180 is the yellow catridge error. Try cleaning the contact surface of the catridge and the printer using moistened cotton buds..if error continues, you should clear the error that keeps on displaying.. here's how: press & hold "*" key...while holding, press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...press "1", "2" and "3" to display "Support"...press ">" right arrow button and release when "System Config Menu" appear....press "OK" and/or arrow key to display "Hardware Failure Status"...press "OK"....when "Hardware Failure Status:Clear" appeared, press "OK" to clear...press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....the last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
May 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have an HP Officejet J3600 series, It is showing error code 0xb900001b, 165:hw_interrupt_hwv2.c what am I supposed to do? I tried to clean and check the inkjets and anything I possibly could. Please help...
You could try resetting the printer as a first step.
Leave the printer switched on and disconnect the USB cable from the back.
Remove the catridges and wait for "insert catridges" to be displayed. **Don't insert them! **
When the display comes up, disconnect the power cord from the printer. Wait 60 seconds and then reconnect the power cord and press the "on" button if it doesn't automatically start.
Reinsert the catridges and calibrate if asked to do so. Once this is completed reinsert the USB cord and try to print again.
If this doesn't work you can do a partial reset back to factory conditions.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
The HP website has help for your product series here (including downloads, manuals etc.)
Hope that helps!
Nov 13, 2009 | HP Office Equipment & Supplies
Error Message on screen
Check two things
1. Ink in your catridge
2. Check whether the catridge has been proprely inserted because some movement to the printer may cause the catridge postion to be misplaced
Hope your problem got solved
Please rate my solution
Thank you
Oct 22, 2009 | HP Photosmart 2610xi All-In-One InkJet...
My hp printer f4280 display E on the start/copy screen and colore print catridge display empty but i refilled it. printer does not print. what is the problem?
my printer after i refill still shows empty and not printing.please give me the solution i cannot afford to always buy a new cartridge.thank you
Sep 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Display says "Remove and check right cartridge", but even replacing the right cartridge with a new one does not fix the problem, and the printer will not function.
This HP PSC 1610 all in one - scan / fax / copier *** printer, normally the cartridges inserting
locations might have caused some issue. When you install the genuine catridge and getting the
error. Might be the catridge inserter might be replaced with local hardware engineer is the best solution. Moreover this type of printers are HP itlsef is giving the maximum life of 3 years only as printer life time.
In our office we are using HP PSC 1110 - 4-in-1 printer and it is having the same problem, but when the message displayed, we will just say OK and it will automatically print the necessary pages.
Best of Luck always.
Jul 16, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp 4355 cartridge error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 10, 2008 | HP Officejet 4355 All-In-One InkJet...
CARTRIDGE ERROR LIGHT IS FLASHING: I replaced the black ink cartridge thought that might be the problem...I did the cleaning steps with no luck...HELP
I would like to provide you a weblink of a document related to the Cartridge error that you are experiencing which would be helpful for you.
Here is the weblink:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00428054&cc=us&lc=en&dlc=en&product=441125&dlc=en&lang=en
Please refer the document and let me know the result with the exact message displayed on the All-In-One.
With Regards,
Ashesburn..
Nov 09, 2007 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 3050 All-In-One Printer Logo
189 people viewed this question
Seeker5211
Seeker5211
