Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
Excessive frost build up inside the freezer
We have a PFS22ISBSS model that just started having excessive frost build up/condensation inside the freezer. Is this part of the nationwide recall like the other GE models: GSS, GSH, HSS, ESS, GST, HST. Need help. We have frost build-up on the right hand side, by the light and the top right drawer. It isn't ice, it is more like snow.
    President:
  • 1,902 Answers
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Posted on Jun 01, 2009
Siemens KG39NA00GB fridge freezer auto-defrost problem.
When you defrosted manually, did you get a lerge amount of water down the back of the unit? If not. the drain is blocked. Also clean and clear the condenser
Apr 24, 2012 | Refrigerators
Freezer is not freezing and refridgerator is not cold enough
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by Side Can't find model # Not cooling enough
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
  • The defrost timer
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
Excessive fosting in the freezer compartment
may have a bad drain line heater or a bad defrost heater, thermostat, or timer.
Oct 09, 2009 | Freezers
The divder between my frig and freezer is also hot
This is normal. Modern frost free fridges have heaters built into the front edge of the cabinet to help keep the accumulation of surface condensation and excessive ice build up on the door edges inside the freezer and fridge.
It is nothing to worry about, but you might have an energy saver switch inside the fridge section that you can turn "on" to turn OFF the heaters (energy saver means the power using heaters would be OFF when the energy saver is "on", turning it "off" means the heaters are ON.
But not all fridges have a switch to turn off the heaters, so don't worry, just accept it and don't buy a new fridge until you need to.
Hope that helps, best regards!
Jul 30, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
541 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
