Question about Kenmore 57029 Side by Side Refrigerator
There's a strong smell (ammonia?) coming from the Kenmore refridgerator area
    President:
  • 1,902 Answers
Leaking Freon you will need to shut it down and call out a tech to get the problem fixed, if you keep it running you are going to have prblems
Posted on Jun 01, 2009
Hi, we have a caravan which has an electrolux RM360 gas/electric fridge installed. There is a very weird smell coming out when the fridge is turned on. Its like an ammonia smell it is really strong,
Travel refrigerators use an ammonia coolant instead of freon. So the smell is telling you that you have a leak in the sealed system.
Suggest you look for a replacement fridge OR a rebuilt unit because that is usually cheaper than taking it to a service center for repairs.
Jan 25, 2012 | Electrolux Refrigerators
Had a strong Amonia smell. Fridge wants to turn on but no cooling.
Strong Ammonia smell is dead give away for LEAK. Ammonia is the chief ingredient in the absorption type cooing system. Probably not economical to repair. For a second opinion, contact a Dometic Authorized Service Center.
Thanks for your question @ FixYa.com
May 31, 2011 | Dometic NDR 1292 Refrigerator
The control board has a relay that continues to click in gas mode (upper control board lights show a very faint flickering during this) and the igniter does not appear to be sparking; however the gap on...
If you have ayellowish powder it is most likely the refridgerant and does not always smell like ammonia. You should pull the unit out and do a through inspection of the cooling coil and boiler
Sep 17, 2009 | Refrigerators
I have the same problem with my Kenmore refridgerator
To completely clean a frig of bad smells you will need to remove the back cover of frig and freezer compartment to access all areas. I operated a used appliance store for years and had all manner of stinky refrigerators to deal with so what we did was take out all panels and clean out with bleach and water solution. This took care of most odors. Hope this helps.
Jul 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Ammonia smell - very strong and frig not gettting cold
UNLES YOUR FRIG IS 50 YEARS OLD THE SMELL IS NOT PART OF THE FRIG
IF IT IS LEAKING AMMONIA DONATE IT TO THE SMITHSONIAN
Jul 09, 2009 | Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Norcold 982 will not get cold.
If the there is a strong ammonia odor and no cooling, then you probably have a leak in the system somewhere. These types of absorption units must be repaired in a specialty shop. The most common place for a leak is the condenser coil, but can also be the evaporator inside the unit, if the odor seems to emanate from that area.
Apr 06, 2009 | Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
167 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
