Toshiba Satellite A135-S4527 Notebook Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Modem not found
Dial up modem not found
Anonymous
Level 2:
  • Expert 66 Answers
  • Posted on Jun 01, 2009
Anonymous
Expert
Level 2:
Answers
66
Questions
Helped
34581
Points
187
I think ur modem driver is not installed properly so first u uninstall the driver and restart the system and after restarting the system then reinstall the driver properly and then restart the system and then check
2answers
I found a sim slot on my notebook,how can i use it?was it posible that i can use it as a modem?
The slot is used for camera memory cards such as the SD memory card. No, it cannot be used as a modem. However, there should be a jack just like the jack for your phone on the wall of your house, this is the dial-up modem connection. Simply connect it with a telephone cable to the wall from you laptop.
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
1helpful
Does my new Emachine laptop have no dial up modem?
Correct. It's looking for a standard dialer modem. You may just need to go through the internet connection wizard and define how you want to connect. With a wireless adapter, you could locate and connect to internet with that instead of a dial-up modem. Internet connetion wizard comes with Vista and XP and is found: Start > Control Panel > Network connections.
3answers
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
I want to download drivers compatible with windows vista for modem using for dial-up connections.
Please try the following website: http://www.modemsite.com/56k/trouble.asp. This site has a wealth of information and download links concerning Windows Vista, dial-up modems, and compatible drivers for this Operating System. Requires a bit of reading, but hopefully what you need will be found on this site. Best of luck!
When I try to connect to internet with dial up no dial tone
Here is a link to tell you if your modem is working or not.
http://www.56k.com/inits/a2z.shtml
Not sure what modem you have in your system but this is a link for all the modems.
I hope this helps. Pleasre rate.
Missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
1helpful
What is LiteOn Modem DP/N 0H9379. Is this a wireless modem?
It's just a regular modem, LiteOn is name brand, just like Conexant. Also, modems are used for dialing on a land line, and must be connected or hardwired to a land line, there is no such thing as a wireless modem, however there are modems that can communicate with computers through wireless receivers, but they are not considered wireless modems, they're considered and called wireless capable modems. These are generally found in high end office fax machines.
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
