Does not fill properly
I have just got a LG WM-10240F washing machine. the water hardly fills up the washer so plumber came out checked all pressure on hot & cold & they are fine & no problems there, so he said it must be washer, but it happened with my old washer also. so i am not sure what else it could be. do you have any ideas on what this is, or is it jusy a water saving washer, i have no idea, so hopefully you can help me.
You need to replace the faulty cold water inlet solenoid valve.
Posted on Jun 01, 2009
Why is my Lg top loader not filling with water
check ur water inlet valve ur water pressure switch and even ur control board
Jun 21, 2014 | LG WM-2277HW Front Load Washer
When machine is filling with water, pipes throughout the house make a noise. We have a water hammer attatched to both hoses already.
You will need a plumber to help with that problem. The washer is designed to turn on and off the water quickly and there is nothing to change the settings.
Jun 16, 2011 | LG WM-2277HW Front Load Washer
IE water inlet error How do I fix?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 08, 2010 | LG WM-2277HW Front Load Washer
Washing machine
Turn off the water then fit new water solonoid valve
Apr 13, 2010 | LG WM-2277HW Front Load Washer
Errorcode de
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
ar
Feb 16, 2010 | LG WM-2277HW Front Load Washer
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
Own LG Tromm Wm2277hs
may be the sensor? I have the same model and I changed the sensor now it fills.
Jan 17, 2009 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
