Question about HP Pavilion DV6500Z Notebook
When put on,the indicator light comes up breifly and goes off
When put on the indicator light comes up briefly and switches off.it does not get to the booting stage.please help me when i switch the laptop on the lights comes on and goes off again. it shows nothing on the screen.
  • Luc Francoeur
    Luc Francoeur May 11, 2010
    do you hear any beeps from the mboard
    does the cpu fan starts
    does your battery is inserted
    have you checked your battery charger with a voltmeter
    Master:
  • 404 Answers
Buy a new laptop. hp's bios fault
Posted on Jun 01, 2009
My oil light comes on every so often, breifly.
Check the Oil Pressure Sensor. It is located to the left of the Oil Filter. Check the connection, then remove, clean the sensor, reinstall and check operation again. If this does not work, remove again and replace this Sensor. Based on miles (130K) it is about time for a new one.
I'm not a big believer in synthetic oil, but that is my own opinion. I used exactly what is recommended.
If this does not fix the problem, then you should check for a leak. When checking the Oil Pressure Sensor: also check to see if the Oil Filter is tight enough. Was a light coat of fresh oil applied to the rubber o-ring gasket before putting on?
Let me know if this helped, or if you have addtional information or questions. Feel free to contact me on FixYa.com!
Jan 17, 2010 | 2000 Dodge Caravan
I switch on and get 3 beeps. 1st longer than other 2.
The beeps are a result of the POST (Power On Self Test). Follow this link to a list of beep codes...
http://www.computerhope.com/beep.htm
Aug 13, 2009 | Computers & Internet
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
URGENT! My computer doesn't switch on and Ihave a tight schedule.
please try a different ac-adapter, since its most likely defective.
if the powerled just blinks 1 time it usually indicates that the battery is empty and need to be charged.
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Lights come on but goes off nothing comes on any display. this was after someone put a code in it to bypass the brake safety switch. now the lights come on briefly and then everything shuts down
Normally you would ground the safety switch wire and not enter a code of any sort.
You need to reset the unit to factory settings, should be in user guide.
May 08, 2009 | Jensen's VM9312 Car DVD Player
is the light indicator blinking that is the battery light ......... then connect the adapter of the laptop ( power cord ) and start
Apr 04, 2009 | HP Pavilion DV6500Z Notebook
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
HP Pavilion DV6500Z Notebook Logo
107 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
