Question about Sebo K1 airbelt Bagged Canister Vacuum
Central vacuum cleaner problem
One of my fasco central vacuum cleaner motor is not working.
    Scholar:
  • 95 Answers
Fasco has been out of business for several years. The motors are still available. You will need to find the model number off your old unit. Once you have that model number you can find the replacement motor at one of these websites.
https://www.centralvacuumstores.com/motors/fasco.php
http://builtinvacuum.com/help/fasco/motor.html#motor
Posted on Jul 01, 2009
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
My central vaccum cleaner has no suction at all outlets even at the canister. The motor is still working and blowing air out the air release tube. What could be the problem
Check the filter in the tank. If this is dirty, the motor will still run, but there will be little to no suction. Rinse thoroughly under warm water, then allow to thoroughly air dry before replacing into vacuum.
I recommend having two filters in order to use one while the other is drying.
Jan 27, 2011 | Electrolux Central Vacuum
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Jan 21, 2009 | Electrolux Central Vacuum
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Central vacuum motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=720877
Central vacuum motor. Posted by knise on Jun 29, 2008 Circuit breaker attached to a board inside the vacuum shroud “clicks" rather than motor starting?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have a bad replay switch on the inside of the Electrolux Central Vacuum and it needs replacing. They are not too bad as per the cost if you are mechanically able but B4 you attempt to do that I would have it checked by a local vacuum cleaner central vacuum service tech just in case. I will give you the website and the factory phone number for the Electrolux listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Jun 29, 2008 | Electrolux Central Vacuum
Electrolux central vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=491377
Posted by judiths on Apr 05, 2008
Help! It works fine until I plug in a hose and then the unit surges--kind of like its breathing.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a weak motor and when it takes on a load it starts to over load and or surge – but if the motor is still under a factory warranty then contact the vendor who installed it because if you work on a unit that is under a factory warranty then it will void the warrant. It is not the vacuum inlet because that only uses a low volt wire. So if it beyond the factory warranty then contact your local vacuum cleaner dealer in your area or cal the Electrolux factory for further information and or an owner manual on the unit giving them a model # and serial # so they can download the correct service manual for you. Your motor may be in need of service but be careful that the repair and labor does not exceed the cost of a new motor.
Go Ahead. Use Us.
Apr 05, 2008 | Electrolux Central Vacuum
Central vacuum
Check the motor brushes, they may be worn down and not making contact with the armature. There may also be relays and one could be bad.
Mar 03, 2008 | Electrolux Central Vacuum
Sebo K1 airbelt Bagged Canister Vacuum Logo
139 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
