Our shredder will only rotate about twice and the motor is running but the blades stop turning - its the same in reverse & I have tried to power off & checked for blockages but to no avail. It has been oiled too. Any other suggestions.
Have you looked at the drive gears. If you turn the motor gear by hand you should be able to see if any teeth have been stripped. I'm not sure about Royal but you may have trouble getting any parts.
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
