Question about IBM ThinkPad G40 Notebook
Bios password ibm thinkpad g40
Im working w/ my laptop just fine, but when i restarted it i keep getting error 0271. i need to configure time & date setting but i can't get tru the bios password. i don' remember putting password on my bios! i already replace my cmos battery but still nothing happen. i need help! tnx. . .
  • 3 more comments
  • Anonymous Feb 15, 2008
    i get the same thing
  • Anonymous Apr 12, 2008
    SYSTEM PASSWORD FOR GOT ASKING TIME DATE
  • barahona_ni Sep 26, 2008
    error 0271 check date and time settings and before password bios
  • hatem1981 Nov 23, 2008
    i don' remember the password on my
    bios! i already replace my cmos battery but still nothing plz Help
  • ana peralta
    ana peralta Dec 13, 2013
    not have the same problem I get the bios screen and asks me password .. my whatsapp 809-257-6723, plis help
IBM G40 CMOS battery ?
Posted on Apr 27, 2009
CONTA LA ASSITENCIA TECNICA
Posted on Oct 26, 2008
Necesito de urgencia ingresar a la bios de la notebook IBM ThinkPad G40, pero esta con candado. y no se sabe la clave. Como puedo hacer para quitarle el candado y poder acceder a la Bios.
Todo esto se *** porque retire momentaneamente la bateria que trae la placa base, despues realizar eso sale un candado. Pareciera que se activo una contraseña, ya trate quitar la bateria mas de 1 hora y todavia no pasa nada...
Agradezco mucho su ayuda es de Urgencia Gracias.
Posted on Sep 27, 2008
Todo esto paso cuando retire momentaneamente la bateria de la placa base y luego aparece solamente el candado y pide la password
    Novelist:
  • 85 Answers
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Posted on Nov 16, 2007
After i remove litheum battery and restart. error 0271 - check time and date setting is what i saw n it lock again. what is wrong?
It appears the Thinkpad has a password lock on the BIOS.
This password cannot be removed by removing the BIOS battery.
For details on how to remove thisPassword click on this link -
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Mar 10, 2012 | Lenovo ThinkPad R51e Notebook
T30 keeps giving me an Error 0271
Error 0271 Date and time error-Neither the date nor the time is set in the computer. Run IBM BIOS Setup Utility to reset the time and date.
I suspect the CMOS battery needs to be replaced.
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA! Bestregards,
Junior
Sep 23, 2011 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
0271 error
go to the bios and set the time and date there. you also may need to load the default settings to reset the bios to remove any bios passwords. if that does not work remove the bios battery or move the bios jumper for one minute. to reset it write down all bios settings befor you do it.
Jun 22, 2009 | IBM ThinkPad T21 Notebook
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Error 0271 check the date and time setting
The BIOS battery is flat and cannot keep the corrected date and time. Replace the BIOS battery anf then go into the BIOS configuration to set the time and date.
Mar 13, 2009 | IBM ThinkPad T20 2647 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
My IBM thinkpad A21e is showing me an error message
You need to replace your BIOS battery. The battery is old and cannot maintain the BIOS configuration. That is why you are getting incorrect date and time and bad CRC error.
Replace the battery and then configure the BIOS settings.
Jan 27, 2009 | IBM ThinkPad A21e 2655 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad G40 Notebook Logo
2,294 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
