Chip size can I put 1gb memory in my spare memory slots? currently I only have 1 512 drr pc3200 in. can I use ecc chips.
  • 181 Answers
Yes as long as it is the same ddr and not sdr
Posted on Jun 01, 2009
How much ram can I install on my Averatec 2200?
The ram maxes out at 2GB. There is only one memory slot, so you would need a 2GB memory stick. Hope this helps.
Regards,
Matt
Apr 15, 2011 | Computers & Internet
Can I use DDR400 (PC3200) RAm in my Dell OptiPlex GX260 PC Desktop? Thanks
Yes.
Maximum Total Amount is 2GB.
Maximum Amount for EACH Ram Memory slot is 1GB.
Use unbuffered, low density, Non-ECC.
2.5 volt to 2.6 volt
Chip configuration is 128Meg X 64 for a 1GB ram memory module.
(Ram memory 'stick')
Suggest you watch where you buy it.
Cheap costing ram memory = cheap quality ram memory
Doesn't have to 'break the bank' in cost, but if it's too cheap to be true, it usually is.
Buy from a reputable ram dealer.
Oct 09, 2010 | Dell OptiPlex GX260 PC Desktop
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Memory for the D4362
Your system may have 2 slots for SDRAM and 2 slots for DDR Ram, and must not be mixed, either use only DDR DDR2 or SDRAM. The mobo may only take 2 of the same size sticks e.g 2 x 1GB,or 2 x 256MB, so be carefull as you may waste money on a non recognised peice of ram. If you use a pc3200 and a pc2700 stick it will run at the slower speedof pc2700. Some boards will only allow a certain maximum of ram up to pc3200 speed and then adding any more you will have to run at pc2700 speed. The crucial memory site will be best for advice on memory type allowance and speed.
Jan 29, 2007 | E-Machines D4362 (RBD4362) PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
