Question about Packard Bell (030069) Sound Card
Volume error no sound card or mixer
Can I down load a sound card from another computer if I can how would I do it my computer with the problem is packard bell desktop windows xp home edition but my laptop which I would download the xp sound card is is vista
  • juliafoster8 Jun 11, 2009
    Thanks went onto packard bell web site downloaded driver like you said with the serial number of my desk top and it worked i have now got sound
    Thanks again for all the help
  • Tom
    Tom May 11, 2010
    Software or Hardware ?
    You dont download a Sound Card you install one as a hardware option?
    You can download "Drivers" for a sound card onto any PC to make copies which you can then use on your Desktop or Laptop
  • 489 Answers
I am assuming that you are referring to a sound card driver, not a sound card itself (can't download hardware). If you know where to get the driver, you can download it with any computer. Just make sure you get the one for the oeprating system you will be installing it on. Simply copy the downloaded driver file to removable media (floppy disk if it is small enough, flash drive, CD, etc) or transfer it over a newtork. If it is an embedded sound controller on the motherboard, you will need to download it from the Packard Bell website. Make sure you get the one for your specific computer model. If it is an add-in card, you may need to get the driver from that manufacturer. Again, you will need to know the specific model of the card to get the proper driver.
Posted on Jun 01, 2009
I have purchased a peavey pv 6 (not the usb) and I have a squeal problem when I activate the tape to mix button and rising the master fader to 0 and my headphone volume. I am using a creative soundblaster...
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Jun 28, 2011 | Peavey PV6 Mixer
Why my computer did not detect sound.. even if i check the control panel sound volume and mixer working properly.. i try to install sound card same result...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 16, 2010 | ASUS 90YAA0C00UAN00Z Xonar Essence STX...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
This is the active mixer error message... --------------------------- Volume Control --------------------------- There are no active mixer devices available. To install mixer devices, go to Control Panel,...
NO active mixer is one of the volume control, your sound card or your audio port is not installed. try to install again your motherboard installer and locate for the audio of it of for the soundcard. Then after that restart and when the sounds come then you successfully installed it
Jan 10, 2010 | Computers & Internet
I'm having problems setting up my numark tt1625 turntables with the mixer. I can't hear any sound even with volume on full. do I need an amp or is the equipment broken?
Double-click the Volume Control icon (beside your computer's clock, on the System Tray) to open the "mixer". Ensure that you have no "sliders" that have been set to "zero" ("no sound").
Connect the turntable-output to the "blue" (audio-in) socket on your computer's sound-card.
If you get no sound, move the connector to the "pink" (microphone-in) socket on the computer's sound-card, and try again.
Nov 26, 2009 | Nu Mark Numark (CD2CD) CD-RW Burner
No sound
have you got the right sound card software?? have you checked if you speakers are hooked up correctly and that all of the cables are intact?
Jul 12, 2009 | Computers & Internet
Volume&thinkpad button
Most IBM / Lenovo Thinkpads have hardware volume control with apropriate buttons above the keyboard (volume up, down and mute). Gnome in Ubuntu is configured in such a way, that the keypresses are trapped (this is correct), apropriate volume window is displayed (correct) and Gnome volume control is modified. Last step is actually wrong - the keys in Thinkpads control the volume hardware directly, so every keypress turns the volume up/down regardless of sound card settings (in Ubuntu case - this would be Alsa mixer). Current behaviour results in volume being changed twice - for example if I press the volume up button, I get volume reduction via Gnome sound mixer plus volume reduction via hardware control. Effectively this creates an exponential (and not linear as it should be) volume change. In short - it is very difficult to control volume, especially relatively quiet sounds, with volume keys only.
The "patch" solution is to decouple Gnome mixer from hardware buttons. Of course it could be done manually, by deleting apropriate key actions in System->Preferences->Keyboard shortcuts, but this also disables windows showing volume. A better thing (but more complex) would involve reading /proc/acpi/ibm/volume and displaying the volume window according to this value at each volume button keypress.
I tested this on T21, T42 and Thinkpad 600. I guess only some R series notebooks (R31 etc.) would not be affected, as these do not have hardware mixer.
Steps to reproduce:
1. Press hardware volume key (eg. volume up) on a Thinkpad
2. Observe the volume change - it is changed in hardware mixer (correct) and in Gnome volume control (incorrect)
I hope this helps...
Apr 18, 2008 | IBM ThinkPad R31 2656 Notebook
There is no sound
Plug the speakers into the green connector first of all.
Make sure the speakers/amplifier are working on another source.
Since you have the volume control on your systray (it is there, right?), you do have an audio card installed (or integrated one at least).
You might try this forum also to troubleshoot the error message about there being no mixer device:
http://forums.techarena.in/showthread.php?t=44823
This has to do with a WinXP WIndows Update perhaps.
Mike
Nov 12, 2007 | Audio Players & Recorders
Packard Bell (030069) Sound Card Logo
161 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
