Ram classification dynet dnkm5u512b&te-a4 ddr400(3) 512mx8 s/n: rmin-630048to this is whats' on the ram stick. now what PC is this so i can buy a new stick as i'm totally confused with this one pls
  • dragoness1
    dragoness1 Jun 01, 2009
    ah dude, that is so cool. how did you know that one. thank you so much now i can go shopping
  • 489 Answers
DDR400 memory is PC3200.
Posted on Jun 01, 2009
I want to increase the speed of Which type of ram should I use to increase speed of my pc ?
RAM will not increase the speed of your computer. The processor on the motherboard provides a given speed, such a 3 GHz or whatever. It is possible, however, that you need more RAM if you run too many programs or are playing games that need lots of RAM. Go to your manufacturer's website and look up the specs - it should tell you how much total RAM your motherboard will support as well as which type. Go to control panel, then to system. How much ram you have will be listed there. Once you have this information, you can decide if you want to buy more. I have found it is usually best to get RAM all at the same time, from the same place.
Jun 05, 2016 | Intel Computers & Internet
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
My memory at present is 512 mb I need to add more memory. Where do i buy it? where do i fix it?
www.newegg.com
There go to computer hardware, memory, and choose the memory configurator. It's usuall on the lower left of the page. There you can plug in your pc or motherboard model number and it will give you compatible memory for your setup.
Mar 21, 2011 | Computers & Internet
Hi I have intel motherboard D945GCNL with Dynet 1 GB ram installed. I boght a new Dynet 1gb ram and installed it. After that, my cpu began beeping.So I removed the ram and interchanged the rams.It doesn't...
Your RAM needs to be:
  • DDR2 667, DDR2 533 or DDR2 400 MHz SDRAM DIMMs
  • Non-ECC DIMMs
  • 2 GB maximum total system memory
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: double-sided DIMMs with x16 organization are not supported
  • Make sure the New RAM is not bad.
    Ensure that the new RAM is the same type as your old one (DDR2 XXX)
    Install the old one back and make sure that your PC works.
    If it does, Take the Old RAM out and install the New RAM in the same slot as the old one.
    If the PC does not work with the new one, It is more than likely a bad stick of RAM
    Hope this helps
    Dec 20, 2010 | Intel D945GCNL Motherboard
    My computer is hanged if i installed d dynet ram in my pc.
    It may be the fact that, although you've got the correct type of ram, you've bought the cheaper high density ram and your pc will only run on low density ram.
    Remove said ram and log on to the Crucial and/or Orca websites, both are reputable and they have a scan function.
    This will tell you exactly what type and how much ram your pc will take.
    You don't have to buy from them, but the info is good and the ram would be guaranteed.
    Nov 15, 2010 | Computers & Internet
    P5RD2-VM recognises only 2 GB
    According to Asus, the max supported memory is 2 gig. That second stick of 512 is not needed and the error shown is in memory configuration.
    Hank
    Aug 03, 2009 | ASUS P5RD2-VM Motherboard
    Computers & Internet Logo
    693 people viewed this question
    David Payne
    David Payne
