New hard drive
Been told i need a new harddrive as my laptop cant find it in the bios is this right
  • 489 Answers
If your laptop doesnt see you HDD in Bios,  that rgiht
Posted on Jun 01, 2009
Bios no longer detects the harddrive
Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
Jan 14, 2014 | Toshiba Satellite M55-S331 Notebook
Hi im getting the pxe-e61 media test failure check cable for a toshiba a350 i have gone into the bios and disabled the lan and put my hdd is slot 1 followed my my cdrom i bought a new harddrive but...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty.Thenthe hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Aug 03, 2011 | Toshiba Satellite A35-S159 Notebook
Laptop says no operating system found wot do i do as its a samsung notebook
Check if the harddrive is detected in BIOS (Basic Input/Output System) setup by pressing F2..or F12 (depends on what key is designed for the BIOS setup).
- If the harddrive is detected in the BIOS (usually shows the harddrive name or values beside "Drive 0"), your operating system is corrupted. You need an operating system disc to install it.
- If the harddrive is not detected in the BIOS ( no value beside "Drive 0"), either the harddrive cable is loose, the harddrive is not inserted properly or is defective. Check the harddrive compartment at the bottom of the laptop and use screw driver to reveal it. Try to reinsert it or use a good known hard drive.
Hope this helps.
Jun 10, 2011 | Samsung N150 Notebook
Lap top can't find hard drive
Here are some steps that you can try.
- Check if the harddrive is recognized in the BIOS (Basic Input Output System). Normally you will see values beside "Drive 0" at the first page if the harddrive is detected. If it says none or blank, then it is not detected. Reload BIOS default settings and try to boot up the unit to see if it will pick up the harddrive.
- If the harddrive is not detected in the BIOS, you need to unscrew the harddrive compartment at the bottom of the laptop.
- Reinsert the harddrive and check harddrive cable. Also try to use a good known harddrive if yours is defective.
Hope this helps.
May 27, 2011 | Samsung Notebooks 14.1 W P460 Professional...
Why does my laptop say system operator missing
System operating missing means that your laptop cannot find a operating system to start. This could be that your hard drive have crashed or overheated or the laptop is not detecting your harddrive. You might want to go into your bios menu and see if the bios is detecting your harddrive, and if it is not, it could be that your hard drive is bad. The only way to test this out is to take your harddrive and connect it to another computer to see if it is working. If it is working then there could be a loose connection between the hard drive and the laptop. If the bios detect your harddrive, then that means your operating system is currupted and needs to be fix or reinstall.
Jan 13, 2011 | Computers & Internet
My lacie hard drive turnes on ,shows that its running,stops running and keeps showing pink light but does not show appearance on my laptop,
Right click "My Computer" and select Manage. In the window, select Disk Management on the left column. If the drive is not listed on the right column, then the BIOS has not detected the harddrive - it might have a harddrive password lock. You will need to go into the BIOS and unlock it with the password.
Nov 01, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
N800v harddrive blew out
It depends upon your needs, the larger the hard drive to higher the cost and the maximun size you can install depends upon the BIOS. The smallest hard drive that is readily available is about 100Gb.
Jun 15, 2009 | Compaq Evo N800v Notebook
New hard drive
you got a problem there.
may be you can return it and get a 80GB harddrive. e-mail me fo rinstruction how to install update BIOS.
Sep 30, 2008 | Fujitsu LifeBook B2131 Notebook
I put a new samsung hard drive in my laptop but it won't detect the new drive I dont have the software that came with laptop I was told to install the drive control first but how do I INSTALL it when...
it properly have something to do with the bios.
try to check if the bios detects the harddrive.
if not reset the bios.
hope that if can help you further.
CS
May 16, 2008 | Computers & Internet
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
