Washing Machines Logo
Posted on Oct 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer/Dryer The instruction manual for the Whirlpool washing machine, model AWG320/2, says quite clearly that the red pipe should be connected to the hot tap and the blue pipe to the cold tap, However, both pipes are connected to the hot tap and there does not seem to be any way of connecting the washing machine to the cold tap. How important is it for the washing machine to get access to cold water and what are the consequences of it not being able to do so?
john mc donald
Level 2:
  • Expert 121 Answers
  • Posted on Mar 03, 2008
john mc donald
Expert
Level 2:
Answers
121
Questions
0
Helped
74708
Points
213
It depends if you have a combie boiler if not should be cool but if so would recomend a screw on tap connector from any good hardware store for your cold pipe
I have Model AWZ410 Washing machine, the washing cycle now takes up to 6 Hours!
i have experienced a machine doing this it was caused by the outlet hose pipe not alined it was syphoning water intermittently so check the hose outlet. 2nd
the wash heater may be open circuit causing the wash cycle to stop, the timer is then manually turned to continue washing .3rd check the pressure switch hose for blockage by taking it off the switch and blowing down to clear any blockage.
2helpful
I need an instruction manual for this machine
You can download the needed instruction manual from here:
http://www.whirlpool.hu/app.cnt/whr/hu_HU/pageid/pgsrvifuhome001. Select the model number and click to download "LETöLTéS".
Need an instruction manual
Click on the link below and enter your model number to obtain the instruction manual
http://shared.whirlpoolcorp.com/product_literature/literatureSearch.cmd?form_state=literatureSearch&context=&siteCd=WHRCOM&userType=&searchTerm=AWZ410
Contact Whirlpool Customer Support at: 1-866-698-2538
MY WHIRLPOOL FRONTLOADER DRYER WILL NOT DRYU WHAT'S WRONG?
Check the vent pipe to be sure it is clear if it is a gas dryer you will have to check the ignitor.
3helpful
Whirlpool AWZ412 No Instruction Manual - Dryer
https://www.2instructions.com/search.php?cmarque=WHIRLPOOL&modele=AWZ%20412-1250
Sir, go there and fill the related blanks and order online. EX:- Fill the description with " Front Load Washer " and E-mail section with your E-mail address. Thank you.
Whirlpool 338 leaking from detergent tray
try taking the pipe off and try clearing the blockage by runing the hot tap down it quite fast.
Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
2helpful
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
