Question about GE WWSE5200B Top Load Washer
Washer tank will not hold water
I have a GE washer (model WWE5600G, WWA7050G of WWA7304V according to the energy Star rating tag). On filling the water flows completely from the bottom. It is not a hose (I took the top and back off and checked all hoses) and the water seems to flow from the bottom of the tank. When I look down from the top, the water gushes out from near the bottom of the tank on the left. I can't get further down to see exactly where, but the tank will hold no water at all. HELP!
  • 1,543 Answers
You can remove the front panel by using a putty knife to push in on the two clips in the seam at the top of the front panel. Your model number is most likely on the sticker on the very back edge of the washer, as you look over the back of the washer.
Posted on Jun 01, 2009
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Mar 14, 2010 | GE Energy Star WCVH6260F Front Load Washer
Why does it take so long to run a load of laundry in my GE Profile front loading washer?
Check the water supply, if the water supply is restricted in some way it will take a long time to fill, the m/c may need to fill 4 or 5 times in a complete wash.
Nov 19, 2009 | GE Energy Star WCVH6260F Front Load Washer
My ge front loader is not filling with water??
You could have bad water inlet valves or the fill sensor is bad. (some call it a pressure switch)
Nov 13, 2009 | GE Energy Star WCVH6260F Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
My ge model wbvh5200j2ww washer wont't start. it has power on the panel but doorwon't latch or start filling.
If the pump filter is clogged, the washer won't even turn on. This filter is located behind the small access panel at the bottom on the front of the washer. Remove access panel, flip down scoop, and unscrew filter. You will need a bowl to catch water that comes out(may smell bad). Pull out filter, clean, and replace. Washer should work normally afterwards.
May 01, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE front loading washer not draining water
Something must have gotten into the drain pump. You drop the fromt panel on most of theses and open the pump sump, get the coin or whatever out of it.
Mar 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260
Quite possible your pump is clogged, you have to dismantle.
Try these sites:
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
Pl rate me.....................
May 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WWSE5200B Top Load Washer Logo
154 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
