Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
DJM600 Channel 3 One side of my speakers wont work on channel 3.
Does anyone know how to fix my mixer? On channel 3 one of my speakers, (cant remember if its left or right), doesn't work. Is there a easy fix to this?
Thanks
Charl
    New Friend:
Firstly check it's nothing before you get to the mixer, i.e headphones are working correctly and so are both speakers. If you're sure it's the mixer you could take the chance and carefully open it up. Give the inside a good blow or even hoover (being very carefull) then look for something obvious like a dry solder joint. Anything more serious needs to be looked at by a proffessional.
Posted on Mar 25, 2013
  • 135 Answers
Just bought the mackie 1604 vlz3 mixer and cant figure out how to get sound to the main speakers, the speakers and amps are connected correctly
Simplest is to use the LR button at the bottom of the channel strips you want to send to the main mix. Make sure you set the gain for each channel in use so that the clip light just occasionally blinked then back off a fraction.
If you want to use sub channels assign the strip to the appropriate one 1/2 or 3/4 and the assign the sub to the main mix and bring the subs up.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
Why does the left channel only play out of one speaker
Normally the left channel IS ONLY on one speaker, the right channel is on the OTHER. Give us some more info, please ?
Jun 09, 2014 | Ecler Nuo 2.0 Mixer - Mixer
I bought a XENYX 1832FX and only one channel is working on the main volume.. The led's on left side don't light up.. I have tested leads,speakers,and amp with an old mixer and they all seem to work fine...
There's a button named "Stand By" this is probably the cause of your mixer issue, just take the button cover up and insert the spray cleaner pipe inside and give it 2 or 3 shots, then push it in-n-out several times and re-check the mixer outputs, let me know a bit more to improve help.
Oct 17, 2013 | Music
No power to the speakers no sound
only the left speaker out wont work on either a or b channel anyone know email me mikeyandjessie12@aol.com could it be the speaker wire its 10 gauge speaker wire so idk either channel ive checked its only the left out so i can only listen to the right out on each channel and i cant listen to both channels but does anyone know if you might be able to get a 4 in av cable to a 2 av cable and run 200ws out of this or no
Nov 14, 2010 | Technics SA-EX140 Receiver
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Mar 25, 2009 | Korg Mini Kp Kaoss Pad
Monitor blowen, mixer-monitor channel went out
THE MONITOR OUTPUT AMP MAY HAVE BLOWN...COULD MAY ONLY BE THAT THE JACK IS BAD OR JUST A COLD SOLDER JOINT.....OR IT COULD BE JUST ABOUT ANYTHING IN THE MONITOR CHANNEL PUSH BUTTON MASTER VOL FOR THAT CHANNEL TAKE IT APART TAKE A LOOK AROUND BEFORE YOU BRING IT TO A REPAIR SHOP IT CANT HURT GOOD LUCK
Jan 07, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Connection problem
simple bro. . .. flick the korg kaoss pads setting to send . . u will find this on the back. . . i thin you have it set to direct. . flick it over to send and then let em know if it works. . . and could u answer ASAP what cords you used to connect the kp3 to the send return on your mixer. . .thanx
Dj Nap
Dec 24, 2008 | Korg Mini Kp Kaoss Pad
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Channel mixer problem- No channel B output.
Probably time for an upgrade to a newer channel mixer. Your mixer is probably not worth fixing, but you could continue to use the mixer side for a while until you decide to upgrade that. If you happen to know an electronics tech, it could be a little project to check the power amp insert jack on channel B, but it wouldn't be worth spending good money after bad when you could put it towards more solid gear.
Good luck.
The dude.
Aug 07, 2008 | Peavey 32fx USB 32 Channel Mixer
490 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
