Question about Palm Tungsten T5 Handheld
How do you flash the rom on tungsten t5
Palm T5 quit functioning. After hard reset, touchscreen won't power up. After a period when it refused to navigate using the stylus, after several resets would go to any screen it chose before completely crashing even though battery fully charged before hand. Now it won't power up. I accepted that it would not work with Vista and would not sync but I expected to be able to read the data I have entered. I cannot access anything now.
  • 421 Answers
Sir now you have to upgrade the software of your phone
Posted on Jun 01, 2009
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
Upgraded from tungsten e to tungsten t5 did first hotsync but subsequently get error message line:4038 error launching application
Hello.
From Palm Support:
When you upgraded from the E to the T5, did you precisely follow the upgrade directions? These steps include the following actions:
Did you install the new Palm software that came with the T5? Did you rename the Backup folder on your computer before you synced the T5?
If you did not rename the Backup folder you have installed system and preferences files from the E that are not compatible with the T5 and NVFS.
Advise that you hard reset to return the E to factory condition and precisely follow the upgrade procedures.
Hope this helps.
Jan 05, 2010 | Palm Tungsten T5 Handheld
I have bought a Palm Tungsten T5 which came without installation disc. Can you help.
Here is a link to all the downloads you will need. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/home/page_en.html
Nov 14, 2009 | Palm Tungsten T5 Handheld
I have a palm tungsten t5 and need to link it to my new computer but I can not find the installation cd. Could you advise where I can download from? Thanks Steve
Here is a link to download everything you are looking for for your T5. Best wishes.
Nov 13, 2009 | Palm Tungsten T5 Handheld
Tungsten t5 : Won't power on, despite change of a rechargeable battery, soft reset, trial of hard reset. Any suggestion ? Shall I throw this device away ?
It might just be that the battery is shot and you need to replace just it, I would try that before you throw it away
May 25, 2009 | Palm Tungsten T5 Handheld
Tungsten E2 just stopped while adding data said fatal error
Well had to do a hard reset- lost everything, had no back up, long story don't think I'll bother with palm ever again!
Apr 11, 2009 | Palm Tungsten T5 Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
pls try these steps first
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
otherwise update rom from here
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Mar 03, 2009 | Palm Tungsten T5 Handheld
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Interrupted update - jammed
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Apr 17, 2006 | Palm Tungsten T5 Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
169 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
