My ac want wcome out cold air at home - Heating & Cooling
  • 614 Answers
See if outside unit is running. Check float sitch inside. Check breaker to outside unit.
Posted on Jun 05, 2009
Carrier home AC #BRC036 quit blowing cold air thru vents
Possible indoor fan motor not working or if it's blowing air just not cold air then compressor not coming on on outdoor condenser
Jun 05, 2013 | Heating & Cooling
This is how the problem manifests itself now: - When I picked up the car from dealer two days ago at the border the AC was not at first ice-cold, but after a short while it got ice-cold. - I drove for 90...
Check to see if there is a thermometer built in to the ac controler. It could be dirty dusty or defective. Also check ac fans to make sure one or both are working well and check ac pressure to make sure you have enough freon.
Nov 10, 2012 | Air Conditioning and Heat for Lotus Evora
Where is the 2000 pontiac montana ac mixer
The air temperature control blend door (mixes hot and cold air) I think you refer to is located deep inside the cars heater and AC air duct work. To repeat it you must remove the dash from the car, a job not for home mechanic in most cases. Time to do at home about 12-14 hours
Jul 15, 2012 | 2000 Pontiac Montana
Not getting cold
if no air conditioning on car, probably needs refilling of freeon gas in AC system: this can be done by a garage.
If in a home, same thing, but it may be cheaper to just buy a new AC from Walmart.
Jan 26, 2012 | Heating & Cooling
Just had ac charged on 1995 Chevy Suburban after replacing, nearly, the entire ac system last autumn. Told there were no leaks (vaccum check). However, got the truck home and it still blows warm air and...
you can run the compressor for a few minutes to see if you get cold air with the low pressure switch crossed out. if you don't have cold air after about 5 minutes then you still have a leak somewhere.
Jul 30, 2011 | Chevrolet Chevy Cars & Trucks
Heat blows out driver vent when ac on
this problem is caused by a defective air temperature control blend door actuator motor, it is about center of dadsh in air ducting, it moves the door that diverts air for cold from ac or hot from heater, you must remove the dash to repace it, about a 15 hour job fotr a home mechanic with a factory repair manual, nearly imposs without one.
Sep 04, 2009 | Lincoln LS Cars & Trucks
A/c doesn't get cold anymore
usually means your as unit has lost its charge and can not effectivly cool your home anymore..advise to call a certified ac tech.to find , repair and charge your units.( but in some cases a "starter relay that sits on top of the ac compressor has gone bad..this holds true to fridges also
Jul 30, 2009 | Heating & Cooling
AC does not blow COLD air
not a home mechanic job thats for sure ,check youre pollen filter isnt choked up if thats ok then you need a specialist repairer because the venturi offrice is blocked which means that the high pressure gas isnt going through the small hole causing it to stay hot.must ge er indoors moaning
Jun 14, 2009 | 2000 Chevrolet Blazer
Home AC Air Handler is making Annoying clicking sounds randomly
It sounds like the problem is with the louvre swing motor which is either opening or closing the louvre but not stopping at the end. This is due to a faulty intergrated circiut (IC) programmable chip on the PC board. Only way to get around it is to replace the board.
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
