Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Foot pedal on Motorguide is out of time with steering...
I have one of my steering cables popping loose from the bottom of the foot pedal. I reinstalled the cable and adjusted the tension. However, the foot pedal should be level when the motor is set to go straight ahead. It is off time just a little. Can someone tell me how to calibrate/set steering on the dual cable MotorGuide Tour edition trolling motor? i have a tracker pro series trolling moter and the stearing cable went bad in it can someone plz help me find a new one
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
    Problem Solver:
  • 11 Answers
U just tight it with a not then try and revert.
Posted on Jun 01, 2009
Works when foot pedal is not in place on floorboards but not when foot pedal is installed on floorboard
is there anything that is causing the wires to bind or come loose when its put back in
Feb 14, 2016 | Peg Perego John Deere Gator HPX
2007 Pontiac G5 Base Coupe gas pedal sticking at times
Check the pivot point of the accelerator pedal and lubricate if possible. Check for freyed (broken) wires at the cable ends and check for kinks if you have a cable
Feb 06, 2013 | Cars & Trucks
How to change brake light switch
You'll have to drop the lower dashboard panel to access the switch. There are two clips on the bottom/back behind the pedals. One is white and behind the brake pedal, the other attaches to the left foot plastic floor mount. The white clip can be rotated to come off of the dash panel. The left foot floor mount can be removed with the recessed nut near the top and then separated from the dash panel. There are 5 screws affixing the dash panel to the framework. Two are obvious, on the bottom corners. One is accessible after removing the fusebox cover. The other two are next to the steering wheel and are accessible after popping the small shroud piece off from around the steering column. The shroud is held in place only by clips. After dropping the panel, the brake switch can be found at the top of the brake pedal arm. Disconnect the wiring clip from it and then turn the switch counterclockwise. It will pop out after about an 1/8 of a turn. Should be about a 20 minute job in total. Good Luck!
Nov 07, 2011 | 2003 Audi A6
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
My foot controlled trolling motor pedal is slipping when turning
Your cable may have broken or slipped and maybe bending rather than shifting in the sleeve. You may also want to check and make sure all set screws and cable locks are secure.
May 16, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
2,401 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
