Question about RIM BlackBerry Pearl 8100
Multiple Blackberry problems on the same phone! Please help!
My Blackberry pearl 8100 is doing multiple strange things.
There are 3 major problems:
1) The blackberry is stuck on lock. Clicked the trackball, it did not respond in anyway, not even displaying the "Keypad is locked" message. Tried to power off, but the phone did not respond. The screen will go to black (like when you go too long without pressing a button) but then flash back on without me pressing anything or rolling the trackball.
2) After multiple battery pulls, I finally got it to unlock and enter the main screen. Now, however, anytime the trackball is clicked, the camera inexplicably turns itself on. I can back out of the camera, but anytime i try to do anything (use an application, read a message) the camera turns back on.
3) After even more battery pulls, a new problem occured. After rebooting, the camera will immediately turn on, and stay on. No button will turn it off. After a few minutes, a message will come up that resembles the save picture prompt, but it says the file system is full. The phone is now stuck on this message. Sometimes it will take a picture all by itself.
After multiple battery pulls and troubleshooting attempts, the phone continues to cycle through these 3 problems. I have almost 30 unread messages (at last estimate) and I need my phone to be back in working order wery badly.
Please, please help ASAP!
Hi I actually have exactly the same problem. Meetmeinmont, have you found a solution to this problem.
Posted on Jan 22, 2010
  • 407 Answers
I think the easiest way to resolve as many of these issues is by resetting your blackberry.
Hold down ALT+RIGHT SHIFT(CAP)+DELETE keys - I'm not 100% sure this works on your model but it is soft reset.
Go into Options, then select Security Options, then select General Settings, then activate the BlackBerry menu and select the option to wipe the device - Will reset all your personalised settings to default
Posted on Jun 01, 2009
Unlock blackbebrry pearl 8100
Hi, You can unlock a Blackberry Pearl 8100 safer and easier using unlock code. You can get the unlock code for a Blackberry Pearl 8100 from www.superunlockcodes.com/blackberry-pearl-8100/rs12wp9/ at affordable cost.
UNLOCKING STEPS FOR BLACKBERRY PEARL 8100
1 - Switch ON your Blackberry Pearl 8100 with your current network/service provider's SIM card,
2 - Go to Options Menu => Advanced Options,
3 - In the SIM Card menu, hold down the Shift (right of the zero, cap) press meppd, (NOTE: You may not see any text appear on the screen while typing meppd)
4 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2, (NOTE: You may not see any text appear on the screen while typing mepp2)
5 - Enter the unlock code.
Oct 14, 2012 | RIM BlackBerry Pearl 8100
Looking for code to unlock my blackberry 8100? what do i need to do? I got the ime # on hand
There are two methods for unlocking Blackberry 8100 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry 8100
IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry 8100
Hope this helps.
Jun 28, 2010 | RIM BlackBerry Pearl 8100
Strange symbol on screen of my blackberry pearl
Generally rectangular box appears when you are in Roaming. After doing the Hardreset still if you are getting rectangular box in your handheld kindly walk into the nearest service center.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
I hope I was able to help you.
Thank you for using Fixya.
Nov 13, 2009 | RIM BlackBerry Pearl 8100
My blackberry 8100 can't open
If you are having problems with your Blackberry Pearl 8100, 8110, 8120 or 8130, you might want to wipe all of the data off of it and start fresh. You may want to try resetting the device first by removing the battery from the unit for about 5 seconds and reinserting it. If that doesn’t help things, proceed with these steps to erase all data on the device.
You may want to backup your data before trying these steps.
1. On the Home screen, select Options.
2. Select Security Options.
3. Click General Settings.
4. Press the Menu key.
5. Click Wipe Handheld.
6. Click Continue.
7. Type blackberry.
All the data on your BlackBerry Pearl will then be deleted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 26, 2009 | RIM BlackBerry Pearl 8100
My blackberry 8110 will not charge
this happened to me and i just shut the phone down took out the battery waited 3-4 mins put battery back in do not turn on phone but put it on charge and it should be ok.
Jan 25, 2009 | RIM BlackBerry Pearl 8100
Please help me plz
Go to blackberrymep.com, there you will find all about blackberry unlocking .
Dec 01, 2008 | RIM BlackBerry Pearl 8100
Free unlock of blackberry pearl 8100
It's a clear and fully detailed guide on how to unlock a BlackBerry 8100:
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter network mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
Aug 02, 2008 | RIM BlackBerry Pearl 8100
Blackberry Pearl, JVM Error 547
IF YOU HAVE A COMPANY PHONE - CALL TECH SUPPORT
IF ITS A PERSONAL PHONE CALL YOUR PHONE SERVICE PROVIDER ask if there is any special version of software you have to use.
try a hard reset (take the battery out wait 2 mins then put it back in) if that doesnt work...
BEFORE ANYTHING !!!! use the desktop software to backup your data (because you will be erasing ALL DATE on the device) on the BB (if you can) and save the file to the desktop. next go to https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4you need to download (use pull down menu)blackberry desktop software 4.6 and the blackberry devicesoftware (FOR YOUR MODEL PHONE) install the desktop software first thenthe device software.. this can take maybe an hour (not including thedownload time) once your done use your desktop software to restore yourdata
GOOD LUCK - Please rate this solution :]
Jun 06, 2008 | RIM BlackBerry Pearl 8100
Please help
the phone is locked from working with any SIM card other than a TMOBILE SIM card.... solution is only available by the phone company that distributed the phone orginally.
Feb 19, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
588 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
