Question about Toshiba Estudio 200L Copier
Will not copy
My E Studio 150 copier will not copy the letter L is flashing
  • Adam Peake May 11, 2010
    Is it just L on it's own or L1, L3 etc? Thanks
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; Check all the door is perfect closed !!!
Posted on Jun 01, 2009
What would be causing our Toshiba e-studio 350 copy machine to mis-align margins when printing a document?
This involves 2 different sizes coming from 2 different cassette. 11x17 tray needs adjustment .
Sep 11, 2014 | Toshiba e-Studio 350 Copier
I have e-studio 160. my paper setting is A4 in the cassette try. When i make a copy in platten glass, all the image are complete, But when used the RADF the copy is not complete like, it just like they...
try to reset the copier :
1- turn it off
2- press keys together { 1 - 3 - * } & switch machine on - still pressing the keys until her peep sound
try again & tell me the results
Jun 30, 2011 | Toshiba e-Studio16S Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
Apr 05, 2009 | Toshiba E-Studio 161 Copier
Hi tohisba e studio 150
This is a fuser error.
First you must enter the simulation mode as follows:
press the keys clear, density select, clear, density select
then press the copy key
use the arrow up and down buttons to select the number 14 in the display
press the copy key
this should fix the problem
c
Aug 06, 2008 | Toshiba e-Studio150 Copier
Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
Hi you have a fuser problem. The fuser does not heatup normaly. Sometimes it can besolved with the following code. Enter Sim mode. "c" - Auto/text/photo - "c" - Auto/text/photo - 14 -start - 00 - start. To exit sim mode press clear all. Turn the machine off and on, check operation. If that does not work check the Termosters, termostats, and heater lamps and wiring harnes.
Hope it helps
Feb 19, 2008 | Toshiba e-Studio120 Copier
Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
Jan 22, 2008 | Kyocera RI-3530 Black and White Copier
Toshiba e studio 150 problem
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
Nov 19, 2007 | Toshiba e-Studio150 Copier
57 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
