No Data on disk space all used.
My Roxio software says DVD burning completed sucssfully and the DVD burns but no data shows on the disk
    Problem Solver:
  • 11 Answers
Please check ur CD lens,then use same CD in other drive then we will find the solution.If u find data on other CD rom then lens required to replace.
Posted on Jun 01, 2009
I had burned the data in double layer DVD in Nero, after successfully completing the burning, when i try to open it is showing the space is Zero, please suggest me in retreiving the data which was burnt.
have a good look at the disk you burnt make sure the data has been burnt to the disk
sometimes nero will say that the burn process completed successfully but when you check the disk itself there is nothing on it
righ click on the disk select properties you will be able to see how much free space you have
you would have been asked if you wanted to save the data in a certain folder after the burn
hope this helps
Mar 08, 2011 | Lite On SOHW - 1633S DVD±RW Dual...
DVD drive will recognize data discs but will not recognize DVDs. I.e. when you place a DVD in the drive and open windows explorer you are told that there is no DVD in the drive. However it will...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. This basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Nov 21, 2010 | Acer Computers & Internet
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
When burning dvd movies 5-6hrs.long error msg.not enough space on blank disk. Using Memorex 16X 4.7GB 120min.Blanks
Those DVDs can only hold 120 minutes of video. You'll have to cut up the video footage to 2 hour blocks, or change the recording options to burn a data DVD versus video DVD and compress the 6 hour long videos down to less than 4.7GB total.
Nov 19, 2009 | Roxio Easy CD & DVD Burning
Roxio help
download the latest version of roxio viz roxio creator 10 (if you dont have it) .. disc copier is available in that..
Jul 10, 2009 | Roxio Easy CD & DVD Creator Platinum...
Downloading a programn
If you have a DVD burner in your system, you probably have software that will allow you to burn disks already installed on your machine. The most common programs are Roxio, Sonic or Nero. I haven't used the Roxio software for a long time (since version 3), so I don't know how much as changed in its use. With Sonic or Nero, you just tell it what kind of disk you want to burn (for a program or data file, select data disc). Then add the files you would like to burn to the disk and click on the burn button. A few minutes later you will have a copy of your program burned onto the disk.
If for some reason you do not have any third-party burning software installed on your computer, you can insert a blank CD or DVD into the drive and when the autoplay options appear, select the option for having Windows prep the disk to burn files to it. Or you can even use Windows Media Player to do this too, but you would need to go into open up the Burn menu and select the Data CD or DVD option (instead of Audio CD).
Hope this helps!
May 27, 2009 | Microsoft Windows XP Home Edition
I have roxio creator & my dvd 9.0 de ; how do i burn my movies
I am trying to burn a movie onto a dvd using Roxio easy cd & dvd burning. The problem is that when I do burn it, it burns as a data disc. I try other things on it and it says to use the disc copier application to burn a dvd. I have searched everywhere on this progmram and there is nothing that says disc copier.
Jan 19, 2009 | Roxio Easy CD & DVD Creator Platinum...
DVD not copying
Try a different media brand.
Dec 30, 2008 | Roxio Easy CD & DVD Burning
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
