Konica Revio KD-400Z Digital Camera
Problem for Konica Revio KD-400Z Digital Camera
Not operating.
By jasy on Oct 23, 2007
No operation at all when lens cover slid back.  Dead as a dodo.  Battery fully charged buit still no response.
Same Problem
May 25, 2009
-   Dear Jim,
I have the same problem - camera works when front cover is off, little white switch is activated but when reassembled the front slide fails to activate the on/off white switch above. How to get that slider off though - did you have any luck?
Paul -   macthesage
Jul 05, 2008
-   lens only moves fractionally though battery is fully charged.-   202doll
Dec 17, 2007
-   There is no resistance(as normal) when slide door open but nothing happens. The lens does not move out like normal--not at all----there is no message anywhere----I re-ck the batteries both---put in charger----and neither battery made any difference------In the past I had 3 experiences where a tiny tiny piece of grit got lodged---usually was difficult to move slide when that happened and blown out was good again---using either airgun or inone case just my persistant blowing at it worked but this seems differenct.-   DrDoris
Solution #1
posted on Nov 20, 2008
Not Rated)
jimwing
Rank: Apprentice
Rating: 100%, 1 votes
Hi
Sounds like the problem with mine - the fault is with a broken mechanism that operates the switch. The front cover can be removed (carefully) by unscrewing the six tiny allen screws retaining the front cover (two on the bottom and two each side).
Once the screws are removed gently lift off the front cover, you can then see how the slider pushes the small white (on mine) lever, to activate the mechanism - this can be done with the cover off to test it out.
Haven't been able to find a repair scheme yet, so I might resort to some micro mechanical modifications as I like the camera.
Not a fix I know but I hope this helps a little
Jim
Was this helpful?
Yes
No
Popular Solutions for Konica Revio KD-400Z Digital
Questions and Unsolved Problems for Konica Revio KD-400Z Digital
Do you recommend Konica Revio KD-400Z Digital Camera?
Answer
Answer
i have a nikon coolpix p5100, ppictures are now now clear and appear with lines in the view finder
Answer
sistem error s0042,drop kamera from hands ,witch open lenz.
Answer
System error S0041, S0041, S004E, A00B i open allready the camera, how i can repair?
Answer
hi, I have a Konica KD-400Z.... battery fully charge (although does not last long0... took photos... (More)
Answer
Hi, I have the Konica Digital Revio KD-400Z, The lens has stopped going in and out and is now stuck... (More)
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
