Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Fill beans message keeps coming up on jura capresso impressa s9
We are having problems with the grinder I think.  We have removed all beans according to manual, let machine dry out, taken grinder shield off and vacuumed out area, used grinder tool to turn grinder - nothing seems to work.  Everything else on machine is fine, including when you put pre-ground coffee in funnel - that works fine.  It doesn't seem like anything is stuck in the grinder.  I would love to get some advice on this the Jura impressa S9 comes up with messag fill beans but when I do the message is still their. Also when I push the button for a cupof coffee,the amount of water is very little.( I don't know if this is be connected with the message above) Hope that someone can help me to solve the problem.
  • Anonymous Mar 27, 2014
    error message 6 comes up on our jura s9 coffee machine. What is it?
    Sniper:
  • 60 Answers
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Posted on Jun 02, 2009
  • Morten Bergendahl Jun 02, 2009
    On this model there`s no sensor in the bean container. The message Fill Beans is generated during the tamping or compressing of the grinded coffee. On the motor there`s an encoder that reads out how many turns the motor has before it stops. If this is to long, the logical explaination for the machine is that there`s not enough coffee, ergo you have to fill beans.
    Usually this happens because the grinder is packed with fine powdered coffee that`s blocking the outlet from the grinder.
    You need to take off the toppanel; there`s 7 Torxscrews (could be Phillips if you have an older model). When you lift up the panel you get right to the grinder. Be sure to mark the position of the grinder. Theres 3 colored marks that shows the medium position. Turn the black plastic collar counter clockwise until it stops, then lift off the knives. Clean up everything inside, but never touch the centerscrew, this part is balanced on tiny springs and steelballs. You will probably not be able to get this back again correctly. When you reassemble the grinder, remember to check the colored marks.
  • Steve Boer
    Steve Boer Apr 13, 2013
    I'm having this problem with my Jura Ena 3, can you tell me how to open it up?
3 Suggested Answers
  • 4 Answers
SOURCE: Jura Capresso Impressa S9 water won't pull into the unit
mnbkjnjk
Posted on Jun 16, 2009
SOURCE: Jura Capresso Impressa S9- no steam
Great solution - solved 80% of the problem I had - would also add to check the pressure relief valve (back of pump where water lines to thermo blocks attach). Noticed presure was still low after cleaning solenoid. Ran steam with cover off top (cup warmer plate) and notice water flow in clear line at top (you will see the line). Went to pump, pulled off hose block at back of pump, and popped (carefully) off the black cap which separates the water to the brewer from the steamer. Cleaned this needle and seat, and the spring too, and the pressure now is extremely high at at the steamer wand. 100% fix now.
Posted on May 12, 2010
My Jura Impressa S9 does not GRIND?
Juani, can you use ground coffee in your machine. Then go and find the grinder and put some coffee beans in and grind them.
while enjoying your coffee read the user manual for the coffee machine and find out what the trouble is. If you can't find the manual, you can get it here Free User Manuals and Owners Guides ManualsOnline com
all the best Kolbrun
Jan 26, 2015 | Jura Capresso Impressa S9 Coffee...
Could be bad grinder or no 12v. The display/control runs on 5v and there is a transformer (supplying 5/12vdc) where the a/c cord comes in. Mine was blown from lightening.
Try these guys... they have parts, trouble shooting and videos on youtube.
http://www.partsguru.com/JuraCapressoImpressa.html
Jura j5 keeps indicating beans need filling once a button for coffee has been depressed. then indicates ready again. Beans are full and I have tried blocking off the sensor (beans full) but still the...
Sometimes certain beans do not move freely throughout the grinder. Oily beans, which is not necessarily a bad thing, do not fall into the grinder easily and tend to stick. It is necessary to sometimes to just poke or stir the beans around with your finger to make sure they fall into the grinder. For a safety measure do this while your machine is turned off.
Apr 20, 2011 | Jura Capresso Jura / Capresso IMPRESSA J5...
My Jura Ena 5 gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Same thing happening to me right now. I think this has something to do with having used flavored beans (which I was warned not to do). Supposedly they gum up the machine.
Nov 27, 2009 | Jura Capresso Impressa S9 Coffee...
The machine says FILL BEANS but beans are in it...yes, we did run out of beans but now it won't recognize beans. we cleaned it out, grinded , etc...but it still says fill beans. We also rinsed many times,...
Hi
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
Oct 25, 2009 | Jura Capresso Impressa S9 Coffee...
My Jura Impressa xs90 keeps stating fill system, even after filling the system several times for the last 3 days.
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Oct 15, 2009 | Jura Capresso Impressa S9 Coffee...
I have a s9 avantgarde keep getting error fill bean even though i have plenty of bean in the hopper
Seems Problem with the bean sensor. you need to get the same replaced. there are no setting that can be done manually for bean sensor.
A Jura Engineer can check the Bean sensor with his computer system and confirm if the bean sensor is faulty.
Sep 15, 2009 | Jura Capresso Impressa S9 Coffee...
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
6,049 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
