Question about Microsoft Computers & Internet
How to Check what is the path you have given for the executable. It should be "..\bin\" then it will create executables and dll on your porject's bin folder.can i change that default location
  • 1,511 Answers
Yes! it will be under Project Properties.
May vary a bit, depending on the Version of your VB.
Regards,
Waqar.
Posted on Aug 21, 2009
How do you find an exe file?
Modern software cannot be moved this easily. The Executables require DLL libraries and many other accessory files as well as the fact that they need entries in the windows registry to function. The only way is to reinstall from the original source of the software. Even if you find the exe file you can't just copy it onto another machine and expect it to work. If you are curious about the location of an exe file and you have a shortcut link to the program on your desktop then right click on the shortcut and select properties from the drop down list. The line listed as TARGET will show the entire path to the executable file.
Apr 30, 2014 | Toshiba Satellite Computers & Internet
How to use adodb connection in visual basic version 6?
To use Connection String, we have to set the Connection String to a valid Connect String and then calling the Open method we can open the Connection by passing the connection string as first argument. Now a command object is created with Record set Open method that is given as argument. Then command is executed by command.Execute metod and resulting amswer is saved in recordset created.
Jun 28, 2010 | Microsoft Step by Step Visual Basic 6.0...
Where i can get software for C Programing language and what is the software name...........?
STEP 1 : Download the Borland Compiler
https://downloads.embarcadero.com/item/24778
STEP2 : Run the setup program
By default, it should install everything to C:\Borland\BCC55
STEP 3 : Add the /bin directory to the system PATH
>C:\Borland\BCC55\bin\bcc32 OR >c32
After the setup program is run (step 2), a whole bunch of executable programs are placed in a new directory : C:\Borland\BCC55\Bin. This step makes it possible for the Operating System (Windows) to find these new executables by name. If you don't do this, then you will need to specify the full path to bcc32 every time you use it.
To do this on Windows XP
Bring up the Environmental Variables :
•Right Click "My Computer" ( Depending on how your system is set-up, "My Computer" is either on your Desktop or in your Start Menu )
•Select "Properties"
•Activate the "Advanced" Tab
•Click the "Environmental Variables" Button
Append ";C:\Borland\BCC44\bin" to the PATH variable (figure 3-2)
•Select the PATH variable under User Variables
Note: The PATH variable may appear under both System Variables and User Variables. This How-To changes the User Variable.
•Click the EDIT button below the list
•In the "Edit User Variable" box that pops up, move the cursor to the end of the Variable Value field
•Add a semi-colon ";" to the end of the current value
Note: If the value is empty, then you do not need to add a semi-colon
•Add the path "C:\Borland\BCC55\bin" after the semi-colon
•"OK" your way out of the dialogs
STEP 4 : Set up some configuration files
you should create a configuration file for the bcc32 program that tells it where to find its libraries and include files.
•The file should be named bcc32.cfg
•It should be placed in the same bin directory where bcc32.exe is located
(C:\Borland\BCC55\Bin)
•The contents of the file are the command line options for bcc32 stating the location of include files and libraries:
-I"C:\Borland\BCC55\Include"
-L"C:\Borland\BCC55\Lib"
Regards,
Soul_srch007
Dec 06, 2009 | Microsoft Windows XP Professional
After starting the laptop. it won't do anything when you select a program to open . error loading C:\progra~1\mywebs~1\bar\2.bin\m3plugin.dll the specified module could not be found. hour glass stays
Hi..
In that case your laptop is already infected by the virus, came from your mp3, and it's also display the dll, you need to reformat your laptop the causes of that problem is the virus which is blocking the files you want to execute.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | Toshiba Satellite A135-S2276 Notebook
How to download epson lq-300 plus II printer driver?
1. Create a folder on your C drive and name the folder "Epson"
2. Download the driver and save it in the Epson folder that you created
3. Open the folder, and run the executable file if there is one.
4. If no executable file, then click on add a printer, and follow the prompts
Jun 11, 2009 | Epson LQ 300+ Matrix Printer
JAVAC IS NOT RECOGNIGED AS AN EXTERNAL OR INTERNAL COMMAND OPERABLE PROGRAM OR BATCH FILE''
Your PC - not the calculator - printed this message. It means that the PC tried to execute the Java compiler, but couldn't find the program. Either the Java compiler is not installed, or the PATH environment variable is not set correctly.
To install the Java compiler follow the instructions for installing J2SE at java.sun.com To fix the PATH environment variable: right-click on My Computer, select Properties, select Advanced System settings, select environment variables, edit or create a new variable called PATH in the system or user settings with the path of the javac.exe program. This is often found in c:Program FilesJavain (it's in a java...bin directory somewhere)
Mar 02, 2009 | Texas Instruments TI-83 Plus Calculator
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
Error=0xC0000022
RESOLUTION :
  1. Go to SYSTEM32 folder
  2. Locate the MSVBVM60.DLL file and right click on it, and select Properties
  3. Go to the Security Tab
  4. Click on Add. Type Everyone and hit OK
  5. Back at the Permission form, make sure Everyone is assigned Read & Execute permissions
  6. Click OK
Regards
ELLIN
Sep 19, 2008 | Computers & Internet
FIREFOX executed an invalid instruction in
http://www.fix-all-dll-errors.com/npswf32.dll/
The problem is due to the npswf32.dll file. You can find solution here...just follow the link.
Feb 04, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
