Question about IGN Entertainment (G60503A) Joystick
G60503A I have a G60503A joystick that I've had for some time. Due to moves, changes to a different computer, I am unable to determine if I ever had any sort of manual or software. If required, where/how can I obtain a manual and or software for this device. My grandson is to the point where he wants to "play games" on the computer and utilize a joystick instead of the number pad/arrow keys. Thank you Jan Wetherill jbw5473@embarqmail.com
  • cburton08 Sep 16, 2008
    I need drivers for this joystick and cannot seem to find anywhere to download them. HELP!
    Scholar:
  • 164 Answers
Com fault codes
This flash error code of 9 indicates a communication fault. With this model the problem is usually the connecting cable between the joystick and the computer module in the base. Check the connectors and wiring and cover on this cable for loose,broken , or disconnected terminals and wires. I usually replace the cable with a known good one to test. The second component that may have failed is the joystick assembly. A local dealer may be able to lend you these parts to test or you can purchase them on-line. There are several different models and joysticks that are similar looking but have subtle differences. If you post your joystick model I can be more specific.
Hope this helps.
Apr 04, 2014 | Invacare Pronto M51 Power Wheelchair
My vision sport power chair won't move. the
says here thats a right motor fault, check the right motor connections and cableing
Sep 02, 2013 | Health & Beauty
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
I like to change the language
Put the switch next to the little picture of the camera and arrow in a box on the arrow in a box. This is Playback Mode.
Move the joy stick left and down twice, this will bring you to Setup. Move the joystick right and up twice (or down 20 or so times) and you will be on Languages. Press the joystick right again and you will be given a list of languages and hit menu/Set on the one you want.
Some of the menu items get moved around with different versions of firmware, but this should give you a good idea if yours is different. Good luck!
My firmware is version 2.1
Jan 09, 2011 | Panasonic Lumix DMC-LX3 Digital Camera
Damages joy stick, cannot move up, down, left and right
Most of the time joystick problem can be corrected by :-
-put some servicing liquid like petrol on joystick area and move your joystick up dpwn left right
then dry your board .
- most of the time this problem will be solved by this process. if not then change your joystick
Oct 20, 2010 | Sony Ericsson K700
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
WILL NOT CONTROL AIRCRAFT HAS NO LIFTOFF
I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though.
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts......
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now.
Oct 09, 2009 | Logitech Extreme 3D Pro Joystick
Most of the time my the left button joystick remain unactive
ur set must be old. actually ur joystick needs a cleaning. it might be due to lot of dust.. but there r more chances tht u will have to get ur joystick replaced. it is a common problem in nokia 6600. mine 6600 down joystick was inactive and when it was active it moved thre 4 times all together. so i got it replaced.. pls rate
Aug 12, 2009 | Nokia 6600
Attack 3 joystick wont opperate on laptop
First of all you want to make sure you install a driver for the joystick. If you have an Attack 3 joystick you would need to download the driver from HERE
Then choose the operating system you are using
If you are not sure of your operating system right click on my computer and click on properties.
Then when you are done downloading the driver run the installation or setup of the driver software. DO NOT PLUG IN YOUR JOYSTICK UNTIL PROMPTED BY THE SOFTWARE TO DO SO.
When the software instructs you to plug in the joystick do so at that time. If your device is not found try following the same process on a different computer. If it works on the other computer you will need to make some changes to how your windows operates. If you continue to have problems Reply to this message and I will find answers to your questions.
Thanks.
Oct 31, 2008 | Computers & Internet
Tiny problem
1. press menu button on the inside of the fold out display
2. use the joystick type button on the display to move to the left menu
3. use the joystick type button and move up 2 times.
4. use the joystick type button and move right.
5 use the joystick type button and move down 9 times to "clock adjust" and press it to select.
6 be sure and press it again to save the changes before you exit the menu
Sep 27, 2008 | JVC Everio GZ-MG130 Camcorder
IGN Entertainment (G60503A) Joystick Logo
701 people viewed this question
Top IGN Entertainment Video Game Consoles & Games Experts
James Wishart
Are you an IGN Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
