Question about Brother MFC 420CN All-In-One InkJet Printer
Brother dcp-130c all in one printer
Where do you drill hole in cartridge to refill with ink
  • 832 Answers
Re: brother dcp-130c all in one printer
LC900 refill
(translate page by help of google (its german)
Posted on Oct 23, 2007
0 characters
3 Points
Asked me to refill ink when i did it is saying no cartridge, tryed it again and turning it off and on and is still saying the same
Hi, remove the ink cartridge and re-insert properly, if it is still same thing, maybe you did not refill the cartridge well or perhaps your printer do not accept or support refill cartridges, so i suggest you get a new cartridge and fix properly.
I wish you best of luck.
Jan 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Refilled ink cartridges, printer reads no ink and
This printer has a sensor that can tell how much ink is left, what you need to do, is cover the ink tank with a black tape, that way the sensor thinks the tank is full...
Dec 08, 2009 | Brother DCP 130C All-In-One InkJet Printer
My DCP 130C is not printing Blue and I have just
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Dec 01, 2009 | Printers & Copiers
better use this generic ink carts, which work pretty much better than the original ones :o
(LC1000 is identical to LC51)
There is much trouble by refilling original carts, because of the ink which might clog the ph.
Anyway if you keen on inky-fingers, malfunction ph and maybe bad printing results: - Refill
(use google translation german)
Apr 30, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-130C
Apr 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
103 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
