Question about HP Compaq Presario CQ50-110US Laptop
How do i disable the tap om my mousepad
It highlights everything when i move around
  • HP Master
  • 19,396 Answers
To disable the touchpad, follow instructions on website below:
Disable Touch Pad of your Laptop
Posted on Jun 01, 2009
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
Mousepad Problem
I assume we are discussing a trackpad.
It's possible that your have your "tap to click" feature enabled, and you are inadvertently tapping the trackpad while you are sliding your finger around. Visit Apple Menu / System Preferences / Trackpad to set your trackpad controls in a way more comfortable for you.
If this doesn't solve your problem, you will have to provide us with a more specific description of what actions you are performing, and what actions the Mac is performing.
May 04, 2010 | Apple MacBook Pro Notebook
Hp Paviliion dv4-1365dx .....When I type all of a sudden the cursor will jump and I'll be typing into what I have already typed (just did it)....very frustrating HELP!
Unfortunately the touchpad of most laptops is very sensitive. This will cause the slightest nudge of the thumb or wrist to move your mouse and possibly even "click". In order to avoid this issue and associated frustration, I always 1) disable the touchpad when I have an external mouse plugged in and 2) disable the "tap click" feature. Follow the instructions below for these two suggestions.
Disable touchpad
  1. On my system there is a small button just above the touchpad that disables it, yours might as well. If not, go to Start>Control Panel> Mouse>Device Settings>and Device. Highlight the Disable Button.
  2. Follow the same steps as above but instead of Disable button select Device button and select the Tapping option and unselect "enable tapping".
Good Luck,
NOLA Tech
Feb 06, 2010 | Computers & Internet
Gateway laptop running Vista suddenly developed an issue with the mouse pad.... double click doesn't respond. However the touch pad works to move the mouse
I have just had this problem with an Acer laptop running on Vista Home. When I double clicked on the actual pad itself rather than the bottons, it wasn't recognising it at all. Wouldn't scroll down or select a folder etc, just if I double clicked on the actual pad. Everything else worked OK.
I tried the solutions above but they didn't work.
Turns out it's the 'Tapping' function that needs to be enabled. Go to Start > Contol Panel > Hardware > Mouse > Device Settings > Then it says devices: and lists what pad hardware you have (mine is Synaptics Touchpad V7.2.
Under the box are 3 buttons Enable, Disable and Settings, presuming yours is enabled go to Settings > Tapping > Enable Tapping. Hey Presto! :-)
Aug 21, 2009 | Computers & Internet
Mousepad, right clicker problems on ibm thinkpad t41
you can try looking at the manufacturers website for a driver update to your trackpoint http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#mouse
Try turning off the tap to click option. This should resolve accidentally dragging things where they don't need to be.
Better option...if you're using this laptop at home just invest in a wireless mouse and set the laptop to disable the trackpoint when an external mouse is detected.
trackpoint=mousepad=touchpad
Jun 10, 2009 | IBM ThinkPad T41 Notebook
Asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
Mar 16, 2009 | Computers & Internet
My touchpad mouse wont click. it moves around but i have to use the side buttons to use it.
if you cannot click the easiest thing to do is to click just by doing a quick tap with your finger on the mousepad that should click on things
Dec 21, 2008 | Computers & Internet
Wireless mouse?
Try disabling the mousepad on the laptop. sometimes this is what causes the problem. Another reason might be the mouse batteries. If they are running low you might experience problems like that.
Apr 18, 2008 | Computers & Internet
Permanent settings in control panel
function and f7 key disable and enabled mousepad
Oct 19, 2007 | Acer TravelMate 2300 Notebook
HP Compaq Presario CQ50-110US Laptop Logo
308 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
