HP DeskJet D1460 InkJet Printer Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
The light on the power button is blinking, the printer doesnt print at all. it appears online and ready, the printing jobs are queued and it says "printing" but nothing happens. i tried to remove each cartridge but still it didnt work. the thing is we already did a print test the day it was installed which was a few days ago and it worked. could it be the port? it was connected to the usb port the first time i tried to print, and the second time i changed it to "lpt 1" according to the troubleshooting instructions. but nothing still.
Ginko
Level 3:
  • HP Master 19,396 Answers
  • Posted on Jun 01, 2009
Ginko
HP Master
Level 3:
Answers
19396
Questions
25
Helped
8074296
Points
55462
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
I just change the ink cartage and now see the power button and stop button light blinking
If the power button LED blinks - you must understand it is not ready. You must power off the printer - restart the computer. Clear the pending printings from printer buffer (Start - Settings - Printers and Faxes - Choose the printer concerned - delete the pending printings). Now reset the cartridge well and perfectly. Now switch on the computer and printer. The LED will be steady. Take print out now.
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Both green and orange lights blinking. Printer
Try deleting all ready to print documents, restarting the printer and then re-booting the computer. Somebody in there is confused.
If that doesn't work, check your documentation on how to print a test page, if it will print then the problem is which the application otherwise re-install the printer.
1helpful
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Printer won't print. amber light blinking.
try to power off printer remove the AC adapter, and hold down power button for 30 seconds, then plug in AC Adapter and power on, that may "Reset" the printer. You may be having an intermittent hardware failure. Let me know if this doesnt work. Thanks for any votes
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
1helpful
2answers
Canon s400 doesnt print only blinks eight times
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
1helpful
2answers
Printing problem
I also own an HP D2360. I had the same problem with eyang and vinerc. I brought the printer to a computer technician and he told me that my color cartridge is busted and needs to be replaced. I bought
a new color cartridge and presto! My printer is working fine.
k24674
Grand Canyon Tech
Grand Canyon Tech
