Question about Comfort-Aire BHD-651 Dehumidifier
Fan does not come on
The compressor will turn on, but the fan itself does not turn on.  The dehumidifier turns off after a few minutes and does not produce any water.  The fan spins really easy by hand when I had it apart.  What could be the problem here?
  • fatcats Oct 26, 2007
    Thanks for the quick response.  I don't have the cash right now for a new better brand dehumidifier, but I can come up with the $40 for a new fan motor.  Thanks again.
    Problem Solver:
  • 5 Answers
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Posted on Oct 26, 2007
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
The machine tries to turn on, and sounds like it is operating, but does not extract water, and turns off after a few minutes
Check to see if it is clean especially in the coil and fin area, if not that may be your problem. If it is connected by an extension cord loose the cord. If this does not resolve it, then it is a compressor related problem such as a bad relay, possibly a capacitor or the compressor itself.
Good Luck,
Gil Shultz
Nov 30, 2009 | Goldstar DH304 Dehumidifier
Dehumidifier not collecting moisture
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jan 31, 2009 | Kenmore 54501 Dehumidifier
01% humidity
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
The compressor only turn on once (GE AHH40LHG1)
before you go to fix it, what is the setting it is at? What is the tempurature of the room it is in? If the setting has been satified the unit has done it job and if it is too cold in the room it will not operate properly either.
Sgt 48
Jun 06, 2008 | GE AHG40LJ Dehumidifier
Dehumidifier runs loud
What is the temperature in the space where you are operating thsi dehumidifier? When you first start a refrigerating system some refrigerant may have condensed into the compressor oil. When the compressor starts the pressure in it drops rapidly. The oil boils and some passes through the compressor valves. After a few minutes of operation this condition normally corrects itself.
May 16, 2008 | Goldstar DH504EL Dehumidifier
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Comfort-Aire BHD-651 Dehumidifier Logo
453 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
